fvOptions results not matching with Analytical solution |
February 18, 2020, 01:44 |
Divyesh Variya
Rep Power: 8 |
Hello All,
I tried to add a sourceTerm in my case. The problem is like this, laplace((a+bT),T) = fvOption fvOption code is, source = q3prime*(1+cX^2) a,b,c,q3prime are constant values X is mesh cell center location T is temperature field Check out results, they are not matching.results.jpg
Divyesh Variya |
February 18, 2020, 03:18 |
Herpes Free Engineer
Rep Power: 13 |
likely usage error. at least what i can say from the info given to replicate the issue (sarcasm).
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Mesh Independance Test VS Matching CFD Results with Experiments | fadoobaba | FloEFD, FloWorks & FloTHERM | 5 | May 10, 2018 09:49 |
Flow 3d results and real Experimental results not matching? | Subodh21 | FLOW-3D | 0 | July 21, 2014 15:52 |
Natural Frequency Values from Analytical and Numerical Solution are different | ppy1111 | ANSYS | 0 | July 16, 2014 21:23 |
comparison with analytical results (1D)and(3D) CFX | Rogerio Fernandes Brito | CFX | 2 | October 28, 2008 21:26 |
k-epsilon turbulence analytical solution | Kieran Hood | Main CFD Forum | 0 | February 6, 2007 07:00 |
