February 17, 2020, 12:29 |
Throttle simulation
Rep Power: 7 |
Hi Foamers,
I need to simulate the flow through an expansion device (basically a throttling process having Joule-Thomson effect) using openFoam 1812. I have gone through the tutorials as well as the forum but still am not sure what solver to use! The cavitatingFoam tutorial is not applicable... The problem to be solved is as follows: A saturated liquid at an elevated pressure P1 passes through an expansion device and forms a two phase flow at a reduced pressure P2. The process is pressure driven without reaction and due to the throttle, temperature changes. I am not specifically interested in temperature change (as it can be indirectly calculated from pressure) but am stuck to pickup the best solver for this. Any advice is very much appreciated. Regards, MJ Last edited by mm66; February 17, 2020 at 14:42. |
February 19, 2020, 17:09 |
Nicoḷ Morselli
have you tried sonicFoam? Thanks, Nicoḷ |
February 19, 2020, 17:32 |
Rep Power: 7 |
Dear Nicoḷ,
Thanks for your reply . I believe sonicFoam should not be used (please correct me if I am wrong) as the flow velocity is rather small... Am currently working on interPhaseChangeFoam (still not sure if it is the correct solver)... Have you had similar experience? Any recommendations? Regards, MJ |
January 20, 2021, 10:47 |
Hey MJ
do you have any update on the solver? did it work with interPhaseChangeFoam? regards |
openfoam, openfoam 1812, solver, throttle |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 03:28 |
Simulation FPEs - turbulence for transient and steady-state? | DaveR | OpenFOAM Running, Solving & CFD | 5 | March 5, 2017 16:06 |
Pressure drop over throttle disappears (simpleFoam --> pipe simulation) | highpressuretube | OpenFOAM Running, Solving & CFD | 18 | December 21, 2016 13:07 |
Flow through throttle valve in NX flow | Ashwath | Main CFD Forum | 0 | August 10, 2016 12:43 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 04:16 |
