March 18, 2021, 01:44 |
#21 | |
thanat
Rep Power: 5 |
IMG_0182.jpg is it gonna be like this one? Also,what does this code really mean. IMG_1616046182.146886.jpg In the line which contains the cod "fftFreq 1024" |
March 18, 2021, 18:45 |
#22 | |
Guanjiang Chen
Rep Power: 6 |
I don't know the first picture you show is from which case. It seems to be the spl result. The spl I got is similar. I also want to know what the fftFreq means. I think it is a variable for the fft process. As I calculated the spl using my own code, I didn't focus on this number too much. Also, I tried different values for the fftFreq, the results didn't change. If you get the exact answer, please tell me. Regards, Guanjiang |
March 21, 2021, 15:41 |
#23 | |
thanat
Rep Power: 5 |
OH can I have your setting pls. I would be great for me. Pheethanat1433@gmail.com Thanks in advance |
March 23, 2021, 08:37 |
#24 |
Guanjiang Chen
Rep Power: 6 |
Hi, I have put my settings in the first page of this thread.
March 23, 2021, 13:47 |
#25 |
thanat
Rep Power: 5 |
oh thanks, And what is your blockmesh dimension and also the setting in 0 and constant file.
I just want to validate with your result shown earlier. i cannot get the result like you with my setting maybe it is about the observer location i set. |
March 23, 2021, 18:34 |
#26 |
Guanjiang Chen
Rep Power: 6 |
https://github.com/unicfdlab/Trainin...cs-OF4.1/cases
https://github.com/unicfdlab/libAcou.../Tutorials-4.1 What I show is from tutorials. I recommend you run the FFWH+cfdbem_3D. |
March 23, 2021, 23:50 |
#27 |
thanat
Rep Power: 5 |
Now, In this time,i just dont want to use BEM for some reasons. I will try it.
March 24, 2021, 08:30 |
#28 |
Guanjiang Chen
Rep Power: 6 |
You can delete the BEM set. just run the curle and fwh.
March 25, 2021, 14:47 |
#29 |
thanat
Rep Power: 5 |
Can i see your blockMesh of the cylinder,also velocity and turbulence setting.
March 27, 2021, 13:08 |
#30 |
Guanjiang Chen
Rep Power: 6 |
I use ICEM to draw the mesh, and use fluent3DMeshToFoam to import the mesh to Openfoam.
April 7, 2021, 06:38 |
#31 |
thanat
Rep Power: 5 |
Also, is there any functions to use hanning window in the lib?
April 7, 2021, 07:23 |
#32 |
Guanjiang Chen
Rep Power: 6 |
May 13, 2021, 07:38 |
Parallel run
#33 |
thanat
Rep Power: 5 |
Can i parallel run AcousticLib
May 13, 2021, 08:35 |
#34 |
Guanjiang Chen
Rep Power: 6 |
August 9, 2021, 21:18 |
#35 |
Morteza
Rep Power: 8 |
I am trying to visualize pressure fluctuation and/or sound pressure level in the flow field on a slice or a surface. As the grid has 8 million volume cells, if I put more than 600 microphones, the solver crashes due to memory limitation. What parameters can be used to visualize the source of the noise?
I have got the contour of dp/dt, but since I am using sliding mesh, it shows weird distribution inside the rotating block of the propeller as shown below. Is there any alternative ideas for visualizing the sound wave? Divergence of velocity also does not represent anything. |
August 17, 2021, 10:11 |
#36 |
Chakshu DEORA
Rep Power: 5 |
Hello Guys,
I am bit naïve in computational aeroacoustics. I found libAcoustic library for propagation of acoustic waves. I am interested in calculating the acoustic signature of a uav propeller. Currently, for aerodynamics I was using steady MRF simulations to get thrust and torque. Further, I would like to study the acoustics using openFoam with the help of FWH - libacoustics. I have some questions as listed below, it would be great if you could help me. 1. Can I use steady RANS to obtain tonal components with libacoustics? 2. What additional things I can utilize with respect to acoustics if I use URANS simulation? 3. Lets say I run a simulation with Hybrid LES + URANS, and I obtain the unsteady pressure distribution. What are the next steps/or (steps before setting up the simulation) with respect to acoustics. I read in some paper where they define FWH surface around a propeller and use FWH libacoustics to get the SPL. How do we define these surfaces, is it a part of mesh? and What is the role of this surface (is it kind of mapping the pressure fluctutation on the surface) ? 4. Also, with hybrid LES+RANS, is it possible capture the broadband noise using libacoustics? 5. As far as I understood, libacoustics is a kind of post-processing utility, I believe I don't need to make any specific changes to my mesh to use it, correct me if I am wrong. I would really appreciate any help on the subject. This forum has already helped me in many ways, I hope to get answer to my questions soon. Thanks in advance. |
January 3, 2022, 18:13 |
Is it possible that libacoustic can be used in openfoam7?
#37 | |
zhang runze
Rep Power: 4 |
I am working on the far field noise of a aerofoil FSI problem, so I coupled openfoam7 and calculix, but I noticed that the libacoustic is used on openfoam4. Is it possible that libacoustic can be used in openfoam7? Thank you very much for your effort on this lib. Best regards Mu 03.01.2022 |
January 4, 2022, 06:42 |
#38 | |
Guanjiang Chen
Rep Power: 6 |
You can try. I used the libacoustics V4 in the OpenFOAM6. Regards, Guanjiang |
January 4, 2022, 16:18 |
#39 |
zhang runze
Rep Power: 4 |
January 4, 2022, 18:23 |
#40 | |
zhang runze
Rep Power: 4 |
I am trying installing libacoustic in openfoam7 in Ubuntu, but after running ./wmakeAll.sh it shows that dell-123@Precision-7920-Tower:~/Downloads/libAcoustics-master/OpenFOAM-4.1$ ./wmakeAll.sh wmake libso . make: *** No rule to make target '/opt/openfoam7/src/OpenFOAM/lnInclude/Xfer.H', needed by 'Make/linux64GccDPInt32Opt/SoundObserver/SoundObserver.C.dep'. Stop. make: *** No rule to make target '/opt/openfoam7/src/OpenFOAM/lnInclude/Xfer.H', needed by 'Make/linux64GccDPInt32Opt/FileInterface/FileInterface.C.dep'. Stop. After checking the directory /opt/openfoam7/src/OpenFOAM/lnInclude/, there is no file named Xfer.H, how do you solve this problem in of6? Best regards Mu 04.01.2022 |
acoustics, libacoustics, openfoam |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 04:18 |
Acoustic analysis using openfoam | 1994bm | OpenFOAM Running, Solving & CFD | 0 | February 15, 2015 03:36 |
acoustic pressure , velocity, etc. study using openfoam | suniljain | OpenFOAM | 0 | January 19, 2010 06:52 |
Modified OpenFOAM Forum Structure and New Mailing-List | pete | Site News & Announcements | 0 | June 29, 2009 06:56 |
OpenFOAM Debian packaging current status problems and TODOs | oseen | OpenFOAM Installation | 9 | August 26, 2007 14:50 |
