How to calculate time derivative for pressure in openFoam?
Old   February 11, 2020, 01:28
Default How to calculate time derivative for pressure in openFoam?
zein elserfy
zeinelserfy is on a distinguished road
I want to calculate the rms of dp/dt,so i want to know if it is possible to calculate dp/dt then use the average field function to calculate the rms value of dp/dt
or use the function ddt2 for calculating (dp/dt)^2 but after than the fields need to be summed for all time step
does anyone any ideas how it can be calculated in openFoam?
the formula is in the following link
http://drive.google.com/file/d/1tYkR...ubkcSxjo4/view
zeinelserfy is offline   Reply With Quote
Old   June 3, 2020, 10:48
geth03 is on a distinguished road
https://www.openfoam.com/documentati...ts_1_1ddt.html
did you try out this one utility?
geth03 is offline   Reply With Quote
openfoam, rms
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
How to export time series of variables for one point? mary mor OpenFOAM Post-Processing 8 July 19, 2017 11:54
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
