OpenFOAM 7 buoyantCavity tutorial-ERCOFTAC test case 79 |
February 6, 2020, 10:14 |
abdikerim kurbanaliev
Rep Power: 16 |
Dear Foamers,
I use buoyantSimpleFoam solver for modeling of ERCORTAC test case. buoyantCavity tutorial of OpenFOAM 7 is used for this purpose. I found the wrong definition of frontAndBack and topAndBottom patches in the blockMeshDict file of buoyantCavity. Maybe because of this mistake we have nonconverging iterations – residuals remaining almost constant during 3000 iterations. Please see the attachment. The second thing that not clear for me why komegaSST model is used for modeling of buoyant low. Kerim |
February 6, 2020, 12:53 |
Rep Power: 16 |
Dear All,
After a small correction of buoyantCavity and using buoyantKE model of turbulence I had an acceptable agreement with ERCOFTAC test case 79. Please see the attached pictures. Kerim |
February 7, 2020, 14:34 |
Herpes Free Engineer
Rep Power: 13 |
Would you please consider to share your tutorial and modification with the community, or even, with the OpenFOAM. It would be very helpful for the community.
Thank you.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 8, 2020, 01:25 |
Rep Power: 16 |
Yes, I will share it with OpenFOAM. It will be pleasure for me,
but I don’t know how to do it. if you help i can do that. Now I have tested all next turbulence models LRR LaunderSharmaKE RNGkEpsilon buoyantKEpsilon kEpsilon kOmega kOmegaSST kOmegaSSTLM kOmegaSSTSAS realizableKE v2f for buoyantSimpleFoam solver. All results are acceptable. I just have problems with SSG model. Main problem is boundary condition for SSG model. I did't find any SSG tutorial yet. |
February 9, 2020, 12:10 |
Rep Power: 13 |
Just open an issue ticket in the OF repo: issue tracker. The rest will be taken care of, I suppose.
May 20, 2020, 13:57 |
Rep Power: 8 |
Hi !
I am doing an analysis of the same tutorial (buoyantCavity) with the version OpenFOAM v1912. As kerim said, there is an inversion of the patches frontAndBack & topAndBottom however the results are still far from the experimental ones because these patches have the same boundary conditions. So what did you change/correct in addition to the above-mentioned one to fit the experimental results? Please see attached my results with OFv1912 in serial & parallel running (4 cores), OFv7 in serial and the data from the ESI documentation (https://www.openfoam.com/documentati...nt-cavity.html) PS: The content in both versions (v7/v1912) is the same & for the results I have kept the tutorial configuration. Last edited by john myce; May 22, 2020 at 05:46. |
May 22, 2020, 05:51 |
#7 | |
Rep Power: 8 |
OF_vs_EXPT_T1.jpg OF_vs_EXPT_T9.jpg OF_vs_EXPT_U1.jpg OF_vs_EXPT_U9.jpg |
September 6, 2020, 08:12 |
#8 | |
Guilherme
Rep Power: 10 |
Can you share with us which modification you have made? Please. This helps the community. |
September 6, 2020, 08:25 |
#9 |
Guilherme
Rep Power: 10 |
I did tests in the same tutorial, out of curiosity, testing the buoyantKEpsilon model and the original, KEpsilon... but there is no difference in the results. What could have led to this?! Perhaps the boundary condition of blockMesh? Or the fact that I used the same BC for both models? Can anybody help me? * I don't know if I can rule out an error in the algorithm, since I use version 5 of OF. |
September 25, 2020, 09:48 |
#10 |
Yann
Rep Power: 29 |
Hello kerim,
I'm also interested in knowing what adjustments you have made on the tutorial setup to achieve a proper convergence! I tried to play around with the numerical schemes but failed to find a good setup. Guilherme, have you checked the residuals on your case? The default setup of the tutorial doesn't allow to get a converged solution (it stops before convergence) If you still need help, don't hesitate to post some graphs, it will be easier to get an idea of what's going on. Yann |
October 4, 2021, 00:05 |
#11 |
Rep Power: 6 |
Hello everyone,
Any update about this problem? I am hoping to hear from you guys. I came across this problem too. Regards, Mike |
October 5, 2021, 05:49 |
#12 | |
Rep Power: 6 |
Would you mind share to us what did you modify in the original test case? Regards, Mike |
November 26, 2021, 01:26 |
#13 | |
Rep Power: 16 |
Please, have a look to the next paper. Critical reviewing of OpenFOAM buoyant cavity tutorial https://aip.scitation.org/doi/10.1063/5.0071571 Best regards, Kerim |
November 26, 2021, 01:32 |
#14 | |
Rep Power: 6 |
Thanks for showing me your work. I'll check on it and see how it will help my problem. Thanks! Regards, Mike |
February 14, 2022, 12:00 |
Please, send me you paper.
#15 | |
Felipe Noh
Rep Power: 12 |
Dear Kerim, please, can you send me you paper "Critical reviewing of OpenFOAM buoyant cavity tutorial", I dont have access to the publication. My mail is fnohpat@gmail.com.
Thanks in advance. Felipe Noh Quote:
February 14, 2022, 21:10 |
#16 | |
Rep Power: 16 |
Dear Felipe, Unfortunately, I haven't permission to share. I am so sorry. |
fluxRequired OpenFoam Versions SimpleFoam Taylor Couette flow tutorial | mörli | OpenFOAM Running, Solving & CFD | 0 | April 9, 2019 12:50 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
ERCOFTAC T3A flat plate test case | Cfdbug | FLUENT | 0 | March 28, 2016 23:37 |
Viscositymodel tutorial, problems when changing test case to cavity | sur4j | OpenFOAM Programming & Development | 1 | December 8, 2013 10:53 |
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) | ArianeJasmin | OpenFOAM Programming & Development | 1 | April 4, 2012 15:11 |
