February 5, 2020, 22:39 |
pimpleFoam runs slower than rhoPimpleFoam
Kosuke Seto
Rep Power: 6 |
I'm trying to simulate the low Mach number flow. I firstly use pimpleFoam because of the low Mach number, but it was so slow. Then, I started to use rhoPimpleFoam and it ran faster. Becouse rhoPimpleFoam needs to solve rho, but pimpleFoam needn't, I first ly thought that PimpleFoam runs faster, but it didn't. Here's the log file of each solver. Used geometry, deltaT and runTime are the same. These are the part of last time step of each. rhoPimpleFoam Code:
Courant Number mean: 0.036513 max: 4.87821 Time = 0.001 PIMPLE: iteration 1 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 DILUPBiCG: Solving for Ux, Initial residual = 0.00647503, Final residual = 4.47952e-08, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.00802886, Final residual = 1.79069e-06, No Iterations 2 DILUPBiCG: Solving for e, Initial residual = 0.00460524, Final residual = 1.584e-08, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.0134054, Final residual = 5.03037e-07, No Iterations 6 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 4.07381e-09, global = 8.16074e-10, cumulative = 4.08312e-07 PIMPLE: iteration 2 DILUPBiCG: Solving for Ux, Initial residual = 0.00189279, Final residual = 3.3992e-08, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.00242582, Final residual = 2.28783e-07, No Iterations 3 DILUPBiCG: Solving for e, Initial residual = 0.00146006, Final residual = 1.41675e-08, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.00106469, Final residual = 9.15342e-07, No Iterations 2 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 7.46023e-09, global = 2.165e-09, cumulative = 4.10477e-07 PIMPLE: iteration 3 DILUPBiCG: Solving for Ux, Initial residual = 0.000564564, Final residual = 3.10279e-08, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.000729992, Final residual = 2.123e-08, No Iterations 3 DILUPBiCG: Solving for e, Initial residual = 0.000476872, Final residual = 2.00902e-08, No Iterations 1 DICPCG: Solving for p, Initial residual = 0.000348436, Final residual = 6.79079e-07, No Iterations 4 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 5.53697e-09, global = 2.12568e-10, cumulative = 4.10689e-07 DILUPBiCG: Solving for k, Initial residual = 0.00107901, Final residual = 8.67088e-08, No Iterations 1 bounding k, min: 0 max: 4.79338 average: 0.0456554 ExecutionTime = 202.8 s ClockTime = 202 s fieldAverage fieldAverage1 write: Calculating averages Writing average fields End Code:
Courant Number mean: 0.0358382 max: 5.41205 Time = 0.001 PIMPLE: iteration 1 DILUPBiCG: Solving for Ux, Initial residual = 2.28422e-05, Final residual = 2.1461e-07, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.000813427, Final residual = 2.42374e-07, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.00736801, Final residual = 7.23368e-05, No Iterations 94 time step continuity errors : sum local = 6.35008e-11, global = 1.2066e-12, cumulative = -2.96628e-08 PIMPLE: iteration 2 DILUPBiCG: Solving for Ux, Initial residual = 7.86165e-06, Final residual = 7.83411e-08, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.000297705, Final residual = 8.88551e-07, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.00674716, Final residual = 6.64599e-05, No Iterations 84 time step continuity errors : sum local = 5.84091e-11, global = 7.84435e-13, cumulative = -2.9662e-08 PIMPLE: iteration 3 DILUPBiCG: Solving for Ux, Initial residual = 2.6318e-06, Final residual = 2.6861e-08, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.000100458, Final residual = 7.50726e-08, No Iterations 2 DICPCG: Solving for p, Initial residual = 0.00350058, Final residual = 3.48472e-05, No Iterations 105 time step continuity errors : sum local = 3.06619e-11, global = 3.39332e-12, cumulative = -2.96586e-08 DILUPBiCG: Solving for nuTilda, Initial residual = 0.000401555, Final residual = 3.25482e-06, No Iterations 1 ExecutionTime = 405.13 s ClockTime = 406 s fieldAverage fieldAverage1 write: Calculating averages Writing average fields End I check them and realized that NO Iterations of P is much larger in pimpleFoam resulting in ClockTime in pimpleFoam is twice as that in rhoPimpleFoam. Perhaps I don't understand the difference of algorithm in each solver very much, so I can't identify the cause of this. I wanna use also pimpleFoam futuristic, so can anyone tell me why and how to solve this. Thank you for any help you can provide! |
February 6, 2020, 01:50 |
Yogesh Bapat
Rep Power: 16 |
You can try to use GAMG for p and smoothSolver for U and turbulence parameters.
February 6, 2020, 02:14 |
Kosuke Seto
Rep Power: 6 |
Thans for replying,Yogesh!
I'll try it and share the result here. I still have some questions. I think that the change of solver may have some effect, but it is not appropriate to comprehend the difference of two solver. Do you have any opinion? Best regards. |
May 27, 2023, 14:12 |
Alireza Maleki
Rep Power: 9 |
Hi, did you find out the reason why pimpleFoam need much more iteration in solving the pressure?
I have the same issue in comparison to rhopimpleFoam and pimpleFoam! |
pimplefoam, rhopimplefoam |
pimpleFoam, rhoPimpleFoam unstable at small Courant numbers (time-steps) | peob | OpenFOAM Running, Solving & CFD | 18 | November 13, 2020 13:56 |
PimpleFoam runs full length even after residuals converge! | walakaka | OpenFOAM Running, Solving & CFD | 3 | February 28, 2018 13:08 |
parallel run is slower than serial run (pimpleFoam) !!! | mechy | OpenFOAM | 18 | August 17, 2016 17:19 |
Pressure stair-step behaviour using rhopimplefoam | joegi.geo | OpenFOAM Running, Solving & CFD | 3 | December 12, 2014 12:10 |
Parallel runs slower with MTU=9000 than MTU=1500 | Javier Larrondo | FLUENT | 0 | October 28, 2007 22:30 |
