Flotation cell study
Old   February 5, 2020, 11:36
Default Flotation cell study
Pablo
Pablo2120 is on a distinguished road
Dear sirs,
I'm beginning a CFD study of flotation cells used in mining industry. To simulate the dynamic behavior of that cells I need to work under the following characteristics:
- Turbulent model (RAS for now... maybe LES in the future if its necessary).
- Dynamic mesh to simulate the rotor movement.
- Free surface (slurry-air interface, but can be water-air for now) because I need to simulate the vortex in the center of the cell (near the rotor zone, like a mixer).
- Bubbles behavior in a future work (maybe with bubbleFoam).
So, for now 02/05/2020 (MM/DD/YY), I would like to know if a similar tutorial for OpenFOAM exists to begin the study with it. The most similar tutorial I've found is the following:
https://openfoam.com/documentation/g...ating-fan.html
Regards,
Pablo.
Pablo2120 is offline   Reply With Quote
Old   February 6, 2020, 15:41
Pablo
Hi everyone;
I've found an appropiate tutorial case for OpenFOAM v7 in /opt/openfoam7/tutorials/multiphase/interFoam/RAS/mixerVesselAMI
As the name says, it is a mixer vessel simulation which uses an Arbitrary Mesh Interface (AMI: rotatory mesh field). I'm interested in the behavior of the air-fluid interface. The simulation of the vortex is an important phenomena for my study. I understand that without the surface tension simulation it's impossible to form a bubble (also because I would need an incredible refined mesh for that). So, I pretend in the near future to add some single bubbles to the simulation to study this phenomena. I supposed that I can made it using bubbleFoam.
The problem is very CPU expensive (solved in parallel with 16 cores). Even for an i9-9900k. It takes about 5 hours to simulate the vanilla problem. Tomorrow I going to change the vanilla geometry for the geometry of a flotation cell and see what happens.
Regards,
Pablo.
Old   October 13, 2021, 01:04
cfd Engineer
ernarasimman is on a distinguished road
Originally Posted by Pablo2120 View Post
Hi everyone;
Regards,
Pablo.
Hi any update on this flotation cell cfd
ernarasimman is offline   Reply With Quote
dynamic mesh;, free surface model, turbulent flow
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
Doubt about parallel processing vishwesh OpenFOAM Programming & Development 0 November 10, 2017 07:20
Partition: cell count = 0 metmet FLUENT 1 August 31, 2014 20:41
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
cell to cell relation CMB Siemens 1 December 4, 2003 05:05
