How do I get Pitch Response for floatingBody overInterDyMFoam case? |
January 23, 2020, 13:27 |
Ahsan
Rep Power: 7 |
Hello guys,
My name is Ahsan and I am doing a thesis on floating bodies. Can anyone please help me how can I get the pitch response along the time for my floating body? After the simulation finishes, in each time directory, there is a folder called "uniform", in there is a file called "sixDoFRigidBodyMotionState". From this file, I have been able to extract heave motion (from centreOfRotation). For example: centreOfRotation ( 0 0 0.0635719114472 ); Kindly if someone can help me, how can I extract the pitch response? There is also another factor called orientation, but I don't know how to read that. For example: orientation ( 0.999999999881 0 1.54541441232e-05 0 1 0 -1.54541441232e-05 0 0.999999999881 ); I need my pitch response in degrees. It would also be very kind if someone can tell me how can I get RAOs (response amplitude operators) in heave, surge, and pitch. Thanks a lot |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 15:53 |
Changing the grid on the same set-up | Katya | FLUENT | 7 | October 8, 2009 17:31 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 13:24 |
Turbulent Flat Plate Validation Case | Jonas Larsson | Main CFD Forum | 0 | April 2, 2004 11:25 |
Body force - Does it work? | Jan Rusås | CFX | 5 | August 27, 2002 10:50 |
