January 19, 2020, 15:14 |
Rotating duct with SRFSimpleFoam
Rep Power: 6 |
Dear Foamers,
I'm super new with OpenFoam and I'm facing some issues (I couldn't manage to get a converged solution) in a case that I have to simulate with SRFSimpleFoam in foam-7. The case is a rotating duct (100rpm wrt the x axis) through which water flows. It is a really simple case and I cannot understand what is wrong with it. Because of simmetry, only a sector of 20° is meshed, with cyclic AMI used at periodicity patches. As boundary conditions I set an inlet total pressure (101325 Pa, considering that the density of water is 1000 kg/m^3, we have 101.325 M^2/s^2) and an imposed volume flow rate at outlet. I attached an image of the domain and all the text files set to run the case (in polymesh I only left boundary because of dimension limits, but if you want the mesh I can try to find a way to share it). Do you have any idea about what is the mistake I'm doing? Thanks in advance, Lorenzo |
January 21, 2020, 06:26 |
Rep Power: 6 |
Modifying the BCs the problem was more or less fixed (setting an inlet velocity field and an outlet static pressure).
Unsteady simulation of rotating duct SRF or Sliding mesh | Alisa_W | FLUENT | 7 | January 22, 2019 06:34 |
SRFSimpleFoam: Flow rotating right after pure axial inlet | yambanshee | OpenFOAM Running, Solving & CFD | 3 | October 19, 2018 04:25 |
Rotating duct stress Analysis using OpenFOAM | shinjanghosh | Structural Mechanics | 0 | February 12, 2018 14:40 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
Problem with rotating and non rotating bc's in SRFSimpleFoam and MRFSimpleFoam | jcespada | OpenFOAM Running, Solving & CFD | 2 | May 13, 2015 10:39 |
