January 19, 2020, 07:48 |
Fluctuating velocity magnitude
Rep Power: 6 |
Hello everyone,
when running the simulation, the velocity magnitude fluctuates quite significantly between the iterations/time steps - e.g. iteration x: v. magnitude=0.7; iteration x+1: v. magnitude=1.8; iteration x+2: v. magnitude=0.7 … The inlet velocity BC uses a ramp with steadily rising velocity...shouldn't the velocity magnitudes of the time steps also rise in this manner, or is this fluctuating velocity magn. behaviour rather normal for water (surely turbulent from a certain inlet velocity) flow? Setup=pisoFoam, komegaSST… Regards, ras27 |
January 19, 2020, 08:55 |
Rep Power: 6 |
PS: The solution seems to be to increase the # of non-orthogonal correctors in this case
Velocity Magnitude for Steady state RANS | Manu4CFD | FLUENT | 4 | June 15, 2019 00:11 |
kindly help me .. i have and error at line number 147.. | m zubair | Fluent UDF and Scheme Programming | 0 | February 10, 2019 11:25 |
UDF comilation error. urgent help please | m zubair | Fluent UDF and Scheme Programming | 4 | February 10, 2019 11:19 |
How to improve Velocity magnitude | ravi | FLUENT | 0 | June 23, 2003 13:17 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
