[HOW TO] solve the velocity components (Ux and Uy) from 2 equations
Like Tree2Likes
Old   March 6, 2020, 13:16
Question Fornulation
  #21
Kumaresh
Kummi is on a distinguished road
Send a message via Yahoo to Kummi
Thank you for your response ^_^
Here is a thought: instead of solving an equation for U, simply calculate the other quantities such as p2, del X U, and then directly update the velocity instead of solving an equation for U.
p2 can be solved only after calculating velocity (U). and then how to calculate del X U explicitly as such ? I couldn't get it here..
  1. From velocity matrix equation --> velocity is solved (with velocity as only dependent variable).
  2. In pressure equation, p2 is solved after solving velocity (pressure equation contains velocity variables on R.H.S of the equation)
Basically in OpenFOAM, pressure and velocity will be coupled, but not in my case.
Keep in mind that this approach probably needs a carefully drafted formulation.
I am not familiar with this problem, so I cannot help with the formulation, and I don't know what potential issues may crop up in doing so. Perhaps you can find some insight in the literature?
Could you please give me some hints about the drafted formulation, which you are talking about and in terms of literature too.
Thank you
Kummi is offline   Reply With Quote
Old   March 6, 2020, 14:43
Adhiraj
adhiraj is on a distinguished road
I don't get what is so hard to understand here. Here's what I mean:
  1. At any time level n, you have a velocity \mathbf{u}^{n}, and a pressure p^{n}. At time t = 0, \mathbf{u}^{n} and p^{n} are obtained from the initial conditions.
  2. Using the value of \mathbf{u}^{n} obtain quantities such as curl of velocity, and any other terms needed to solve the pressure equation.
  3. Solve the pressure equation to obtain p^{n + 1}.
  4. Using the values calculated in steps 2 and 3, compute \mathbf{u}^{n + 1}.
  5. Repeat the loop until your criterion for convergence is met.
You will need to work out the details, since I am not familiar with this particular topic. Try to find in the literature how other people have worked on this topic.
adhiraj is offline   Reply With Quote
Old   March 8, 2020, 14:29
Kumaresh
Thank you for your comments.
One of my friend helped to find a way somehow, however not that clear (by cross-checking with icoFOAM incompressible solver). Some manipulations are made here without affecting the flow physics.
Ustar = dummy*U;
fvVectorMatrix UstarEqn // Solving velocity
fvm::ddt(Ustar) // UNIT -1/s
+ (fvc::curl(U)) // UNIT -1/s
- ((U^(fvc::grad(God)))/(0.4343*(God))) // UNIT -1/s
solve(UstarEqn == fvc::grad(Foam::sqrt(p2))*dummy2); //Solving "UstarEqn" w.r.t "p2"
U= Ustar/dummy; //Updating "U"
Ux = U.component(vector::X);
Uy = U.component(vector::Y);
solve
fvm::laplacian(p2) == - (2*T*R)*((God*RRg) + (rho*(Ux+Uy)*graddUx)) // solving pressure
runTime.write()
volScalarField dummy
IOobject
"dummy",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("dummy", dimensionSet(0,-1,1,0,0,0,0),1.0)
The units of dummy and dummy2 variables are adjusted accordingly.
After compiling the above code, the velocity is resolved, however when time increases, the magnitude of velocity increases randomly as shown in the attachment.
Old   March 13, 2020, 03:33
Kumaresh
My code is compiled good, velocity contour changes appropriately. But there is problem with magnitude of velocity - which varies in very random manner. In general, my case is steady in flow. But, I introduced unsteady (fvm::ddt) term - mainly for the compilation of matrix equation. When running unsteady case,
  • For t=2s, U =36 m/s
  • For t=50s, U =3,321 m/s
  • For t=100s, U =6,743 m/s
  • For t=200s, U =13,587 m/s
This magnitude changes are really unrealistic. In above thread, I attached the velocity contour plot.
In order to resolve this unrealistic magnitude changes, I tried changing boundary conditions and manipulated the code further, but I couldn't able to figure out how to resolve this.
Pressure boundary file
dimensions [ 2 -2 -4 0 0 0 0 ];
internalField uniform 1e10;
boundaryField
hotSide // flow outlet
type fixedValue;
value uniform 1e10;
top // flow outlet
//type calculated;
type fixedValue;
value uniform 1e10;
right
type symmetry; //symmetryPlane; // zeroGradient;
bottom
{ type zeroGradient; }
front
{ type empty; }
back
{ type empty; }
Velocity boundary file
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
hotSide
type calculated;
value uniform (0 0 0);
//type zeroGradient;
/* type inletOutlet;
inletValue $internalField;
value $internalField;
top
type calculated;
type inletOutlet;
right
bottom
{ type noSlip;
type fixedValue;
front
{ type empty; }
back
{ type empty; }
I fixed the above boundary conditions for pressure and velocity.
Any ideas as how to proceed further ?
THank you ^^
