January 17, 2020, 08:27 |
Monitoring Question about p_rgh and U
Rep Power: 8 |
i have a question about monitoring the solver. The solver is interFoam on OFv7, i do a multiphase simulation. Here is a extract from the log: Code:
Courant Number mean: 3.19876e-05 max: 0.495667 Interface Courant Number mean: 1.25627e-06 max: 0.0671976 deltaT = 0.000229651 Time = 0.00630312 smoothSolver: Solving for alpha.water, Initial residual = 1.26653e-06, Final residual = 1.7656e-11, No Iterations 1 Phase-1 volume fraction = 0.580631 Min(alpha.water) = -1.68629e-12 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.580631 Min(alpha.water) = -1.28064e-05 Max(alpha.water) = 1 DICPCG: Solving for p_rgh, Initial residual = 4.84617e-05, Final residual = 2.30721e-06, No Iterations 2 time step continuity errors : sum local = 6.53424e-08, global = 1.90467e-11, cumulative = -5.15105e-08 DICPCG: Solving for p_rgh, Initial residual = 6.84474e-06, Final residual = 3.23296e-07, No Iterations 7 time step continuity errors : sum local = 9.15619e-09, global = -6.09607e-11, cumulative = -5.15715e-08 DICPCG: Solving for p_rgh, Initial residual = 1.88869e-06, Final residual = 9.77306e-08, No Iterations 17 time step continuity errors : sum local = 2.76788e-09, global = -4.499e-10, cumulative = -5.20214e-08 smoothSolver: Solving for omega, Initial residual = 2.03198e-05, Final residual = 3.7555e-11, No Iterations 1 smoothSolver: Solving for k, Initial residual = 0.00470494, Final residual = 2.12755e-09, No Iterations 1 ExecutionTime = 434.44 s ClockTime = 455 s Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { "alpha.water.*" { nAlphaCorr 2; nAlphaSubCycles 1; cAlpha 1; MULESCorr yes; nLimiterIter 3; solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0; } pcorr { solver PCG; preconditioner DIC; tolerance 1e-5; relTol 0; } p_rgh { solver PCG; preconditioner DIC; tolerance 1e-07; relTol 0.05; } p_rghFinal { $p_rgh; relTol 0; } "(U|k|omega).*" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-06; relTol 0; minIter 1; } } PIMPLE { momentumPredictor no; nOuterCorrectors 1; nCorrectors 3; nNonOrthogonalCorrectors 0; } relaxationFactors { equations { ".*" 1; } } // ************************************************************************* // Here now my questions: Why is p_rgh three times solved ? and Why there are no velocity resiuals ? Shouldn't be there Ux, Uy and Uz ? Best regards Kai |
January 17, 2020, 10:25 |
ssa
Rep Power: 7 |
you set
nCorrectors 3; To solve the velocity you should set Code:
momentumPredictor yes; |
January 17, 2020, 10:47 |
Rep Power: 8 |
Thank you very much ssa_cfd ! I will try it and report back. Best regards Kai
