DPMFoam and this Message: new cannot satisfy memory request. |
January 13, 2020, 12:33 |
#1 | |||
Amir
Dear all,
I am a beginner in CFD. I have to hand this project soon and any quick help is appreciated. The project title is a single particle trajectory between two parallel walls in an airflow. I extracted the Geometry from Blender and used snappyHexMesh. I faced too many errors and I solved them. right now there is a problem which I could not solve it. I will upload all the relevant files and the final error. N.B.: I cannot upload the .stl files controlDict Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application DPMFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 9e-18; deltaT 9e-20; writeControl runTime; writeInterval 0.01; purgeWrite 0; writeFormat binary; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; // make basic mesh ? snap true; // decide to snap back to surface ? addLayers true; // decide to add viscous layers ? geometry // Load in STL files here { inlet.stl {type triSurfaceMesh; name inlet;} outlet.stl {type triSurfaceMesh; name outlet;} //cube.stl {type triSurfaceMesh; name cube;} box.stl {type triSurfaceMesh; name box;} refinementBox {type searchableBox; min (-0.707107 -0.707107 -1) ; max (1 1 1);} }; castellatedMeshControls { maxLocalCells 1000000; //max cells per CPU core maxGlobalCells 2000000; //max cells to use before mesh deletion step minRefinementCells 10; //was 0 - zero means no bad cells are allowed during refinement stages maxLoadUnbalance 0.10; nCellsBetweenLevels 1; // expansion factor between each high & low refinement zone // Explicit feature edge refinement // ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command ( {file "inlet.eMesh"; level 3;} {file "outlet.eMesh"; level 3;} //{file "cube.eMesh"; level 3;} {file "box.eMesh"; level 3;} ); // Surface based refinement // ~~~~~~~~~~~~~~~~~~~~~~~~ refinementSurfaces // Surface-wise min and max refinement level { inlet {level (0 0);} outlet {level (0 0);} // cube {level (3 3);} box {level (5 5);} // was 4 4 } resolveFeatureAngle 60; // Resolve sharp angles // Default 30 refinementRegions // In descending levels of fine-ness //{volume {mode distance; levels ((0.0006 4) (0.002 3) (0.01 2));}} // was ((0.001 //4) (0.003 3) (0.01 2)) { } locationInMesh (0.00336 0.00065 0.0056); //to decide which side of mesh to keep ** allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 3; tolerance 4.0; nSolveIter 30; nRelaxIter 5; nFeatureSnapIter 15; // default is 10 // New settings from openfoam 2.2 onwards for SHMesh implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract explicitFeatureSnap true; // default is true multiRegionFeatureSnap false; // deafault is false - detects features between multiple surfaces } // Settings for the layer addition. addLayersControls //add the PATCH names from inside the STL file so STLpatchName_insideSTLName { relativeSizes false; // was true layers { //cube //{nSurfaceLayers 3;} // was 3 box {nSurfaceLayers 3;} // was 3 } expansionRatio 1.3; finalLayerThickness 0.00016; //was 0.00016 minThickness 0.00008; //was 0.00008 nGrow 0; // was 1 // Advanced settings featureAngle 80; // was 70 //- When not to extrude surface. 0 is flat, 90 is right angle. nRelaxIter 3; //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh. nSmoothSurfaceNormals 1; // Number of smoothing iterations of surface normals nSmoothNormals 3; // Number of smoothing iterations of interior mesh movement direction nSmoothThickness 10; // Smooth layer thickness over surface patches maxFaceThicknessRatio 0.5; // Stop layer growth on highly warped cells maxThicknessToMedialRatio 0.3; // Reduce layer growth where ratio thickness to medial distance is large minMedianAxisAngle 130; // Angle used to pick up medial axis points nBufferCellsNoExtrude 0; // Create buffer region for new layer terminations nLayerIter 50; // Overall max number of layer addition iterations } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { maxNonOrtho 65; maxBoundarySkewness 20; maxInternalSkewness 4; maxConcave 80; minFlatness -1; minVol 0; minTetQuality 1e-9; minArea -1; minTwist 0.02; minDeterminant 0.001; minFaceWeight 0.05; minVolRatio 0.01; minTriangleTwist -1; // Advanced nSmoothScale 4; errorReduction 0.75; } // Advanced debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1E-6; // ************************************************************************* // Pressure: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 0; boundaryField { inlet { type fixedFluxPressure; phi phi.air; value $internalField; } outlet { type fixedFluxPressure; phi phi.air; value $internalField; } box { type fixedValue; phi phi.air; value $internalField; } //frontAndBack //{ //type symmetry; //} } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class volVectorField; location "0"; object U.air; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type noSlip; } outlet { type pressureInletOutletVelocity; phi phi.air; inletValue uniform (0 0 0); value uniform (0 0 0); } box { type interstitialInletVelocity; inletVelocity uniform (0 0 1.875); value uniform (0 0 1.875); phi phi.air; alpha alpha.air; } //frontAndBack //{ //type symmetry; //} } // ************************************************************************* // Quote:
fvSchemes: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; div(alphaPhic,U.air) Gauss linearUpwindV unlimited; div(((alpha.air*nuEff.air)*dev2(T(grad(U.air))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } // ************************************************************************* // Quote:
Amir |
January 15, 2020, 06:38 |
Please guide me
Amir
Dear all,
I will be thankful if you help me. I still couldn't solve the problems. Thank you in advance. Amir |
