"wrong token type - expected Scalar, found on line 0 the word 'nan' " error observed. |
January 13, 2020, 00:31 |
Saurabh Das
Rep Power: 8 |
In a pimpleDyMFoam rotor simulation, after running seamlessly for 2.3 seconds of simulation time, with Courant number within the limits, the following error is observed: Code:
--> FOAM FATAL IO ERROR: wrong token type - expected Scalar, found on line 0 the word 'nan' file: /media/mslab02/space/STL_Trials/Deviation_0_1/Angle_8/system/data.solverPerformance.U at line 0. From function Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::doubleScalar&) in file lnInclude/Scalar.C at line 93. FOAM exiting Is it the geometry that is causing problems? How do I solve this problem? Any guidance would be heavily appreciated. Thank you. |
June 20, 2021, 07:49 |
Risshi Jain
Hey Sorabh. I'm encountering the same problem for my rotordisk simulations using SimpleFOAM. Were you able to resolve your situation?
pimpledymfoam |
[Gmsh] 3D Mesh conversion from gmsh-2.5.0 to OpenFOAM | Ancioi | OpenFOAM Meshing & Mesh Conversion | 17 | January 8, 2019 23:50 |
The udf.h headers are unable to open- in VISUAL STUDIO 13 | sanjeetlimbu | Fluent UDF and Scheme Programming | 4 | May 2, 2016 05:38 |
Error during initialization of "rhoSimpleFoam" | kornickel | OpenFOAM Running, Solving & CFD | 8 | September 17, 2013 05:37 |
wmake compiling Problem with OF1.5 | openTom | OpenFOAM Installation | 4 | May 3, 2009 14:44 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
