Outlet temperature too low, bc problem
Old   January 10, 2020, 21:22
Default Outlet temperature too low, bc problem
Alex
Sedullo is on a distinguished road
Hello to everyone, I am simulating a natural convection problem, where only the wavy part of the right side wall is heated, the heated air is flowing upward. The temperature of the air entering the channel is set to 300 K and the temperature of the heated wall to 340 K.
I do not understand why the temperature at the outlet is so low, as you can see in the pictures attached. In the second picture the velocity vectors are shown.
I guess the problem is in the bc. Here I copy the bc of the velocity and the temperature.
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 300;
boundaryField
    sideWallheated
        type            fixedValue;
        value           uniform 340;
    sideWallsNotheated
        type            zeroGradient;
    inlet
        type            inletOutlet;
        inletValue      uniform 300;
        value           uniform 0;
    outlet
        type            outletInlet;
        outletValue     uniform 300;
        value           uniform 0;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    sideWallheated
        type            noSlip;
    sideWallsNotheated
        type            slip;
    inlet
        type            outletInlet;
        outletValue     uniform (0 0 0);
        value           uniform (0 0 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
File Type: png Screenshot from 2020-01-11 02-06-24.png (57.2 KB, 28 views)
File Type: jpg Screenshot from 2020-01-11 02-04-56.jpg (63.5 KB, 22 views)
Sedullo is offline   Reply With Quote
Old   January 11, 2020, 02:09
Geir Karlsen
gkarlsen is on a distinguished road
Outlet BC for T should be inletOutlet if you want zeroGradient as flow goes out of the domain?
gkarlsen is offline   Reply With Quote
Old   January 11, 2020, 14:36
Alex
Hi gkarlsen, thanks for the reply.
I did as you said and actually that problem seems to be fixed, the temperature is high also at the outlet.
But now I have a new problem, I observe a strange phenomena, after 140 seconds I can see a sudden lowering of the temperature which lasts for about 10 seconds and afterwards it disappears.
I attach a picture of the steady situation (everything red at the outlet) and three pictures of the sudden lowering of temperature phenomena happening at the outlet.
What do you think could be the reason?
Old   January 11, 2020, 15:21
Geir Karlsen
Looks like reverse flow, which you can confirm by looking at U in the direction of your outlet. If this is the problem it can be mitigated partly by using totalpressure BC instead of fixedvalue. Also you could take a look at:
https://www.cfd-online.com/Forums/op...ow-outlet.html
Old   January 13, 2020, 20:03
Peter Hess
peterhess is on a distinguished road
Hello!
Why the temperatures value in both inlet and outlet is 0?
That do not make much sense.
Increase (replace) those with 300...
At inlet use outletInlet
and
at outlet use inletOutlet
You have those reversed!
Regards
Peter
peterhess is offline   Reply With Quote
Old   January 13, 2020, 21:21
Alex
Hi Peter,
thanks for the suggestion, but actually nothing is changed, it is like that variable did not affect the final result.
Still have this backflow phenomena.
I attach also the bc for p and p_rgh to see if you can see here some problems
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    wall
        type            calculated;
        value           $internalField;
    #includeEtc "caseDicts/setConstraintTypes"
FoamFile
    version     2.0;
    format      ascii;
    object      p_rgh;
boundaryField
    sideWallheated
        type            fixedFluxPressure;
        rho             rhok;
    sideWallsNotheated
        rho             rhok;
    inlet
        type            totalPressure;
        p0              uniform 0;
    outlet
        type            totalPressure;
        p0              uniform 0;
Old   January 13, 2020, 22:00
Peter Hess
Upload the case please!
Old   January 13, 2020, 22:44
Alex
I uploaded the case, thanks for the help!
boundaries condition, temperature bc, velocity bc
Impeller: temperature decreasing, should be increasing artymk4 OpenFOAM Running, Solving & CFD 21 March 10, 2024 20:15
Outlet temperature to temperature boundary condition of velocity inlet. (UDF) dillon Fluent UDF and Scheme Programming 3 March 25, 2018 12:06
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions Vishnu_bharathi CFX 12 November 21, 2017 07:56
outlet temperature jigneshrohit99 FLUENT 1 March 25, 2016 14:26
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
