Lagrangian Solvers in OpenFOAM - Are all parcels modelled as point particles? |
Mustafa
Rep Power: 11 ![]() |
Hello FOAMers,
I have a rather basic question about how Lagrangian particles are modelled in a solver like reactingParcelFoam. Are the parcels necessarily modelled as point particles with the required submodels? If not, what happens when a parcel is greater than the cell size at which it finds itself in? Best, Mustafa |
Gerhard Holzinger
Rep Power: 28 ![]() ![]() |
Particle location is always based on the location of the particle's center of gravity, i.e. its center, since all particles are assumed to be spherical.
Unless you are using the immersed boundary (IB) method, you violate many assumptions used in the CFD-DEM coupling, since it falls into the category of unresolved CFD-DEM. I.e. the particles are assumed to be much smaller than a cell of the mesh. |
lagrange particle, reactingparcelfoam |
OpenFOAM Training, London, Chicago, Munich, Sep-Oct 2015 | cfd.direct | OpenFOAM Announcements from Other Sources | 2 | August 31, 2015 13:36 |
Add lagrangian particles to OpenFoam solver | luchen2408 | OpenFOAM | 0 | June 2, 2015 03:10 |
Exporting particles of lagrangian solvers to Tecplot | maysmech | OpenFOAM Post-Processing | 1 | May 3, 2015 11:08 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 09:04 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
