channel flow, too large reynolds stress <u'u'> near the wall
Old   January 5, 2020, 03:12
Default channel flow, too large reynolds stress <u'u'> near the wall
niewiemnic
spalartallmaras is on a distinguished road
Hallo,
I simulate channel flow for Re_tau=395 for long time, but I have always really large <u'u'> near the wall. I simulate with pimpleFoam.
Inlet, Outlet, left and right are cyclic and walls are wall.
My setup is,
1. nu=2,53e-03 (so 1/nu=395)
2. bulk velocity is about 22-23 m/s (patchMeanVelocityForce on inlet), so wallShearStressMean and u_tau are also about 1. Density is supposed to be 1 kg/m^3.
3. turbulence model is WALE-Modell
4. because Re_bulk is low, I use createBoxTurb before the pimpleFoam.
5. Mesh is really coarse, 32*32*32, because I want to make the mesh fine later.
6. After the flow is turbulent enough, I switch on the fieldAverage1.
but I have always <u'u'> about 20-22 m^2/s^2 near the wall. But it should be about 7-8 m^2/s^2 from Reference.
What will be the problem?
spalartallmaras is offline   Reply With Quote
Old   January 6, 2020, 03:30
niewiemnic
Nobody has idea?
Santiago Lopez Castano
Santiago is on a distinguished road
Originally Posted by spalartallmaras View Post
Hallo,
My setup is,
Which schemes are you using? time step?
Santiago is offline   Reply With Quote
Old   January 6, 2020, 03:31
niewiemnic
Thank you for your answer, I will post it in 5-6h.
Time step is maxCo = 0.99.
Old   January 6, 2020, 06:17
Default fvSchemes
niewiemnic
Here I post my fvSchemes file,
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         backward;
gradSchemes
    default         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linear;
    div(phi,k)      Gauss limitedLinear 1;
    div(phi,B)      Gauss limitedLinear 1;
    div(B)          Gauss linear;
    div(U)          Gauss linear;
    div(phi,nuTilda) Gauss limitedLinear 1;
    div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default         linear;
snGradSchemes
    default         corrected;
wallDist
    method meshWave;
Old   October 22, 2024, 17:30
Shravan
Severus is on a distinguished road
This issue has been discussed and solved in another post.
I am adding the link below so that it could be useful for others with the same problem.
Thanks
Severus is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
Wall shear stress in channel flow sreeyuth OpenFOAM Running, Solving & CFD 2 September 5, 2014 11:02
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
X-Y plot of Yplus in Fluent 5.3 Luo FLUENT 24 April 11, 2000 07:07
