Errors when running waves2foam
Old   January 2, 2020, 17:39
Default Errors when running waves2foam
Jinshi Chen
JinshiC is on a distinguished road
Hi foamers,
I am new to waves2foam and this website. Yet I have encountered a problem when running waves2foam parallel with JOHNSWAP wave generator, wave absorption zone and k-omega SST turbulence model. The error exists after some seconds of running and the error code is shown below:
A process has executed an operation involving a call to the
"fork()" system call to create a child process.  Open MPI is currently
operating in a condition that could result in memory corruption or
other system errors; your job may hang, crash, or produce silent
data corruption.  The use of fork() (or system() or other calls that
create child processes) is strongly discouraged.
The process that invoked fork was:
  Local host:          [[33758,1],58] (PID 209108)
If you are *absolutely sure* that your application will successfully
and correctly survive a call to fork(), you may disable this warning
by setting the mpi_warn_on_fork MCA parameter to 0.
[58] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
[58] #1  Foam::sigSegv::sigHandler(int) at ??:?
[58] #2  ? in "/lib64/libc.so.6"
[58] #3  ? at btl_vader_component.c:?
[58] #4  opal_progress in "/vortexfs1/apps/openmpi-3.0.1/lib/libopen-pal.so.40"
[58] #5  mca_pml_ob1_recv at ??:?
[58] #6  MPI_Recv in "/vortexfs1/apps/openmpi-3.0.1/lib/libmpi.so.40"
[58] #7  Foam::UIPstream::read(Foam::UPstream::commsTypes, int, char*, long, int, int) at ??:?
[58] #8  void Foam::reduce<bool, Foam::andOp<bool> >(Foam::List<Foam::UPstream::commsStruct> const&, bool&, Foam::andOp<bool> const&, int, int) at ??:?
[58] #9  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::needReference() const at ??:?
[58] #10  main at ??:?
[58] #11  __libc_start_main in "/lib64/libc.so.6"
[58] #12  ? at ??:?
Primary job  terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun noticed that process rank 58 with PID 209108 on node pn054 exited on signal 11 (Segmentation fault).
I have searched through this Wiki and someone indicated that this could be due to the poorly chosen boundary condition. However, I still am not able to solve this problem after changing the boundary condition for days. My boundary conditions are:
Alpha.water:
internalField   uniform 0;
boundaryField
    inlet
        type            waveAlpha;
        refValue        uniform 0;
        refGrad         uniform 0;
        valueFraction   uniform 1;
        value           uniform 0;
    bottom
        type            zeroGradient;
    oceanbottom
        type            zeroGradient;
    outlet
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        inletValue      uniform 0;
        value           uniform 0;
    front
        type            empty;
    back
        type            empty;
k
internalField   uniform 1e-05;
boundaryField
    inlet
        type            zeroGradient;
        value           uniform 1e-05;
    outlet
        type            zeroGradient;
    bottom
        type            kqRWallFunction;
    oceanbottom
    atmosphere
        type            inletOutlet;
        inletValue      uniform 1e-05;
    front
        type            empty;
    back
        type            empty;
nut
boundaryField
    inlet
        type            zeroGradient;
        value           uniform 0;
    outlet
        type            zeroGradient;
        value           uniform 0;
    bottom
        type            nutkWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
    oceanbottom
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
    atmosphere
        type            calculated;
        value           uniform 0;
    front
        type            empty;
    back
        type            empty;
omega
internalField   uniform 0.003;
boundaryField
    inlet
        type            zeroGradient;
        value           0.003;
    outlet
        type            zeroGradient;
        value           0.003;
    bottom
        type            omegaWallFunction;
        value           0.003;
    oceanbottom
        value           0.003;
    atmosphere
        type            inletOutlet;
        inletValue      0.003;
        value           0.003;
    front
        type            empty;
    back
        type            empty;
U
internalField   uniform ( 0.0 0.0 0.0);
boundaryField
    inlet
        type            waveVelocity;
        refValue        uniform ( 0 0 0 );
        refGradient     uniform ( 0 0 0 );
        value           uniform ( 0 0 0 );
    bottom
        type            fixedValue;
    oceanbottom
        type            fixedValue;
    outlet
        type            fixedValue;
    atmosphere
        type            pressureInletOutletVelocity;
    front
        type            empty;
    back
        type            empty;
Thank you so much in advance!
Best,
Jinshi
JinshiC is offline   Reply With Quote
Old   January 17, 2022, 12:25
FVP
Francisco Pinto
FVP is on a distinguished road
Originally Posted by JinshiC View Post
Hi foamers,
[58] #12  ? at ??:?
Alpha.water:
boundaryField
    inlet
        type            waveAlpha;
        refValue        uniform 0;
        refGrad         uniform 0;
        value           uniform 0;
    bottom
        type            zeroGradient;
    oceanbottom
        type            zeroGradient;
    outlet
        type            zeroGradient;
    atmosphere
        type            inletOutlet;
        value           uniform 0;
    front
        type            empty;
    back
        type            empty;
k
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    bottom
    oceanbottom
    atmosphere
        type            inletOutlet;
    front
        type            empty;
    back
        type            empty;
nut
boundaryField
    inlet
        type            zeroGradient;
        value           uniform 0;
    outlet
        type            zeroGradient;
        value           uniform 0;
    bottom
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
    oceanbottom
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
    atmosphere
        type            calculated;
        value           uniform 0;
    front
        type            empty;
    back
        type            empty;
omega
boundaryField
    inlet
        type            zeroGradient;
        value           0.003;
    outlet
        type            zeroGradient;
        value           0.003;
    bottom
        value           0.003;
    oceanbottom
        value           0.003;
    atmosphere
        type            inletOutlet;
        inletValue      0.003;
        value           0.003;
    front
        type            empty;
    back
        type            empty;
U
boundaryField
    inlet
        type            waveVelocity;
    bottom
        type            fixedValue;
    oceanbottom
        type            fixedValue;
    outlet
        type            fixedValue;
    atmosphere
    front
        type            empty;
    back
        type            empty;
Best,
Jinshi
Hello Jinshi,
Did you fix this problem? I think it might be related with your compilation. It means that the compilation was not succeded.
FVP is offline   Reply With Quote
Old   January 18, 2022, 11:23
Tony Zhang
zyfsoton is on a distinguished road
Originally Posted by FVP View Post
Hello Jinshi,
Hi Francisco,
I think I had a similar problem when simulating a ship in wave conditions.
Instead of using waves2Foam, I am using OpenFOAM its own wave generation tool.
As far as I know, OpenFOAM has included its own wave generation tool since OFv5.
To start with, I copied the DTCHullWave tutorial case into my own directory then I replaced the STL file and then did my own blockMesh, refineMesh and snappyHexMesh etc. Then I did renumberMesh, the error reported:
--> FOAM FATAL IO ERROR:
Essential entry 'value' missing
file: /home/OpenFOAM/OpenFOAM-7/run/KCSDRIFTINWAVE/0/U.boundaryField.inlet from line 31 to line 31.
Then I had to add value in alpha.water and U files in 0 folder (value $internalField; in both inlet BCs in both files)
Then setWaves and decomposePar ran smoothly without any error.
Finally, running interFoam, error reads: Unknown patchField type waveVelocity for patch type patch; (/0/U.boundaryField.inlet)
I think the same error will reported in 0/alpha.water.inlet as well for Unknown patchField type waveAlpha for patch type patch;
Please let me know if you have any hint to resolve this issue! Many thanks and Btw I am using OF version 7 and the patches of waveAlpha and waveVelocity should have been included in OFv7, and I can run DTCHullWave tutorial case without any error!
Btw, I am not sure whether it is worth installing a third party wave generation tool eg. wave2Foam in OpenFOAM v7?
Any help will be appreciated!
Tony
zyfsoton is offline   Reply With Quote
Old   January 18, 2022, 11:45
FVP
Francisco Pinto
Tony
Dear Tony,
I would suggest you to make sure that the openfoam is well installed in your ubuntu machine.
boundary condition, fork error, waves2foam
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 08:52
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
