[Urgent] Matching results to physical data using interFoam |
December 29, 2019, 03:58 |
Kelvin Au
Rep Power: 6 |
Dear All,
I am newbie to use openFOAM. Recently, I am using the software to produce back-analyses to match my physical results (impact forces on a wall and a deflector, flow velocity, flow depth, and run-up height). The whole setting is attached for your reference. I read the posts in this forum that 'nut' file dominates the boundary conditions. When I use 'nutkWallFunction', the impact force on a wall is ~100N, which is twice times to my physical results. Therefore, I did try to change to 'nutkRoughWallFunction'. Initially , I set all Ks, Cs and 'value' = 0.05 and the impact force on a wall reduced to ~79N. However, when I increase Ks to 0.1, the following error message shown. #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:? #4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:? #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam" #7 Foam::fvMatrix<double>::solve() in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam" #8 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam" #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/interFoam" The mesh after sHM was checked and it is OK. Can I know what parameters I can play to calibrate the numerical model in order to match the physical results? Many Thanks for all kind help. Cheers, Kelvin Last edited by kelvinaaa; December 31, 2019 at 00:29. |
December 29, 2019, 08:39 |
Herpes Free Engineer
Rep Power: 13 |
>> Can I know how to calibrate the numerical model to match the physical results? And what others parameters I can change, so that to match all FIVE parameters I mentioned above?
IMHO, you need to first reduce the extent of your question(s), which is as wide as Kardashian's left butt check, otherwise nobody will be able to give effective help here.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
December 29, 2019, 10:12 |
#3 | |
Kelvin Au
Rep Power: 6 |
Forgive me that I am stuck and frustrating on how to calibrate the model. |
January 3, 2020, 22:58 |
Kelvin Au
Rep Power: 6 |
Apologize that I may be a bit rush, but, it there anyone know what parameters I can play, so that the the numerical results match the physical one?
Many Thanks, Kelvin |
January 17, 2020, 22:26 |
Kelvin Au
Rep Power: 6 |
Is there anyone who can help to debug the problems? Apologize for the rush.
Workbench results not matching CFD-Post | newbietocfd | ANSYS | 1 | December 4, 2019 12:55 |
[OpenFOAM] Paraview and simpleFoam 'forces' results are not exactly matching | Krao | ParaView | 2 | July 3, 2019 04:31 |
interFOAM: different results for similar meshes | bramDeJaegher | OpenFOAM Running, Solving & CFD | 0 | January 31, 2017 19:03 |
OpenFOAM 13 Intel quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 13 | February 5, 2008 06:26 |
OpenFOAM 13 AMD quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | November 11, 2007 00:23 |
