ViewFactor Radiation
Old   December 18, 2019, 11:20
Default ViewFactor Radiation
Mike Jäger
mikejaeger is on a distinguished road
Hi People,
I try to get along with the viewFactor Radiation model. I studied the Theory and than built up an OpenFOAM case. The Simulation runs good but I still have some open Questions which I can't answer with literature.
The viewfactor-model calculates the Parameter "qr", but when I turn radiation off, the temperature Distribution on a zeroGradient wall does not change. So the temperature field is always the same, it doens't matter if Radiation is turned on or off.
In General the results are reasonable in Terms of viewFactorfields, faceAgglomeration (and residuals etc...) except the fact that "T" does not Change with Radiation on.
I used the hotRadiationRoom-tutorial und modified it to be a viewFactor-case. Solver: buoyantSimpleFoam. I also tried buoyantBoussinesqSimpleFoam. Same results.
When I look in the ".H"-files of the solvers, I see that both solvers consider a "radiation-term" in the Energy equation. So I am confused why the temperature does not change.
Do I have to calculate the actual temperature considering Radiation within paraview?
Thank you in advance
mikejaeger is offline   Reply With Quote
Old   December 18, 2019, 14:04
Peter Hess
peterhess is on a distinguished road
CHT +viewfactor model
peterhess is offline   Reply With Quote
Old   December 19, 2019, 05:35
Mike Jäger
Thank you. I already read this thread. This is not exactly my case, because I wonder why the temperature is not changing at a wall with "zeroGradient" boundary condition.
If I use "fixedValue" that is clear, that the wall temperature will not change if radiation is turned on.
But at a "zeroGradient" wall it has to? Or am I wrong?
Old   December 19, 2019, 12:04
Peter Hess
Post the case please!
Old   January 2, 2020, 04:57
Mike Jäger
I copied the "hotRadiationRoom"-tutorial, which is actually a fvDOM-radiation-tutorial and I changed it to a viewFactorcase (see CaseSetup.png).
First I execute "faceAgglomerate"
Create time
Create mesh for time = 0
Agglomerating patch : box
Agglomerating patch : ceiling
Agglomerating patch : floor
Agglomerating patch : fixedWalls
Writing facesAgglomeration
End
Then execute "viewFactorsGen"
Create time
Total number of coarse faces: 70
Calculating view factors...
Writing view factor matrix...
End
And then "facesAgglomeration" and "viewFactorField" in the 0-directory is created (with reasonable values).
In the constant Directory radiationProperties, boundaryRadiationProperties and viewFactorsDict is located:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      boundaryRadiationProperties;
floor
    type            lookup;
    emissivity      0.95;
ceiling
    type            lookup;
    emissivity      0.95;
box
    type            lookup;
    emissivity      0.95;
fixedWalls
    type            lookup;
    emissivity      0.95;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      radiationProperties;
radiation       on;
radiationModel  viewFactor;
viewFactorCoeffs
    smoothing true; //Smooth view factor matrix (use when in a close surface
                    //to force Sum(Fij = 1)
    constantEmissivity true; //constant emissivity on surfaces.
// Number of flow iterations per radiation iteration
solverFreq 1;
absorptionEmissionModel constantAbsorptionEmission;
constantAbsorptionEmissionCoeffs
    absorptivity    absorptivity    [0 -1 0 0 0 0 0] 0.00;
    emissivity      emissivity      [0 -1 0 0 0 0 0] 0.00;
    E               E               [1 -1 -3 0 0 0 0] 0.00;
scatterModel    none;
sootModel       none;
transmissivityModel none;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      viewFactorsDict;
//maxDynListLength          1000000;
writeViewFactorMatrix     true;
writeFacesAgglomeration   true;
writePatchViewFactors     false;
box
    nFacesInCoarsestLevel        20;
    featureAngle                 10;
ceiling
    featureAngle              10;
floor
    featureAngle              10;
fixedWalls
    featureAngle              10;
When executing the simulation with buoyantSimpleFoam the residuals are in an acceptable range and there is the notice that the viewFactors-equations are solved
Time = 1000
DILUPBiCGStab:  Solving for Ux, Initial residual = 0.000665996, Final residual = 1.10894e-06, No Iterations 1
DILUPBiCGStab:  Solving for Uy, Initial residual = 0.00107227, Final residual = 2.26247e-06, No Iterations 1
DILUPBiCGStab:  Solving for Uz, Initial residual = 0.00145211, Final residual = 3.13363e-06, No Iterations 1
DILUPBiCGStab:  Solving for h, Initial residual = 0.000692169, Final residual = 1.15632e-06, No Iterations 1
Solving view factor equations for band : 0
DICPCG:  Solving for p_rgh, Initial residual = 0.00298525, Final residual = 2.88191e-05, No Iterations 51
time step continuity errors : sum local = 1.15563e-06, global = -1.19967e-19, cumulative = -5.61596e-18
rho min/max : 0.696266 1.16051
DILUPBiCGStab:  Solving for epsilon, Initial residual = 0.000605439, Final residual = 1.35487e-05, No Iterations 1
DILUPBiCGStab:  Solving for k, Initial residual = 0.00163685, Final residual = 1.98886e-05, No Iterations 1
ExecutionTime = 295.15 s  ClockTime = 295 s
The results after 1000 iterations is seen in Results.png. It doesn't matter if Radiation is turned on or off. The maximal temperature at the fixedWalls is Always 303.281 K (after 1000 iterations). In my point of view the temperature at the zeroGradient walls must change if radiation is turned on or off. Or am I wrong?
Regarding to the viewFactor-equations the heat flux "qr" at the wall is calculated. Obviously this heat flux is not considered in the energy equation of the solver. What I am doing wrong?
Maybe the boundary condition for the temperature T at the wall must be another and not "zeroGradient"? In that case I didn't find an appropriate so far.
Best regards, Mike
Old   March 31, 2020, 10:07
Yann Guyot
YannGuyot is on a distinguished road
Did you check this thread :
Heated wall by radiation
YannGuyot is offline   Reply With Quote
Old   March 24, 2023, 10:27
Chris
Chris T is on a distinguished road
I know it is a pretty old post but I stumble upon it, as I myself, trying to figure out the view factor model in version 9 of OpenFoam.
In your radiationProperties file you have
maybe all those zeros are the reason your radiation model is ineffective. If I understand correctly with emissivity and absorptivity 0 your surfaces are perfect mirrors with no emission or absorption.
I see that you specify emissivity in boundaryRadiationProperties file. I my case I don't even have such a file and I specify emissivity in the 0/qr file.
Chris
Edit: Never-mind. The fields I mentioned above are only relevant for opaque regions.
Chris T is offline   Reply With Quote
