CFD accuracy in turbulent low speed flow compared |
December 16, 2019, 21:00 |
Sina
Rep Power: 11 |
My question comes from modelling wind in urban context. But there might be a similar question in other applications.
Should we expect to get different velocity ratios (V_local/V_ref,inlet) if we are modelling bluff bodies (essentially blocks with sharp edges) in turbulent incomprehensible flow when using low speed than high speed at inlet? In theory, there should not be different. This is the fundamental for wind-tunnel testing. But in CFD, do we expect to have more uncertainty for low wind speeds? I hope I framed my question appropriately. PS: I am aware of Reynolds number dependency, so limited the case to sharp edged blocks. |
cfd accuracy, low wind, uncertainty |
Too low turbulence in a tank flow compared to experiment | AndyCF | Main CFD Forum | 0 | July 28, 2019 09:57 |
Low Speed flow in Micro Gravity; what model? | Brice | FLUENT | 0 | June 13, 2007 11:30 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
Solving unsteady compressible low speed flow | atit | Main CFD Forum | 8 | July 31, 2000 14:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
