About the totalPressure BC
Like Tree5Likes
Old   December 10, 2021, 06:30
shock77 is on a distinguished road
I think it was at 8e-5 seconds, if I remember correctly. At least somewhere in this range, I have already deleted the case.
Yeah the momenTransport folder must be new, I dont know this one. Also I dont work with the newer versions so I cannot help you with that. Also the error is not helpfull.
I didnt use the setFields folder, I just waited until it converges. It was stable enaugh although the velocity wasnt zero.
At least it is possible, you just have to transfer it to your version somehow.
shock77 is offline   Reply With Quote
Old   December 13, 2021, 10:53
Utkun Malkocoglu
Malkocoglu is on a distinguished road
constant/momentumTransport and constant/thermophysicalProperties files have been in OF versions for a while. But I do not know the exact reason for being different files from constant/transportProperties and constant/turbulenceProperties. By the way, I tried your files and settings with OF v8 instead of my currrent version OF-dev) and it seems to work uninterruptedly (at least for the first 1e-5 secs). But OF v8 needed constant/momentumTransport and constant/thermophysicalProperties as well, it did not begin running until I put these files in /constant directory.
I will keep this run going until it explodes (hopefully never happens) and see what happens. The case is arranged as inviscid; I do not know what will become if I run with turbulence model.
I expect to give some outputs if I can maintain the actual run.
Thank you again @shock77, your contribution is invaluable. And as I always said, please do not disappear on the forum; probably I will need to confer with you again.
Best,
Malkocoglu
Malkocoglu is offline   Reply With Quote
Old   December 17, 2021, 05:37
Glad it works so far and that I could help.
I hope it doesnt blow up!
Keep up the good work and have a nice start in the new year.
And I will stay here in this forum for a while I guess haha.
Old   December 21, 2021, 11:29
Utkun Malkocoglu
Thank you @shock77 for the good wishes. I hope the same for you.
I run the case with OF8 which is different from my older one. It did not blow for 15e-5 seconds and I interrupted.
On the other hand, when I checked the boundary conditions that given by you, they correspond to Mach 1.5 whereas my case has 2.95. Similarly, pressure ratio and temperature values in your modified files are around 10 and 200 K, respectively. In my situation, these values should be around 150-160 and 100-110 K, again respectively. Then, I guess that my temperature is so low that it reaches 0 or its near values.
Best,
Malkocoglu
Old   December 22, 2021, 06:54
Utkun Malkocoglu
Best,
Malkocoglu
So, if the case files still stay in your computer, could you adjust the case in a way that Mach 2.95 and jet total pressure ratio 150? Because when I do that, the case insists to blow. And you solved with rhoCentralFoam, right?
Old   January 13, 2022, 07:06
Hi again,
unfortunately I have deleted the case.
Do you still have troubles with that? That might be due to negative temperatures. Also when it comes to low temperatures, the sutherland law might be not applicable. You should check that for your gas!
Old   October 28, 2022, 12:24
Sakun
Sakun is on a distinguished road
Hi ,
did you mange to solve your issue, if so can provide the solution? cause i am having the same phenomena for my steady-state compressor blade simulation.
Sakun is offline   Reply With Quote
rhocentralfoam, totalpressure
totalPressure (why flux direction dependend) Tobi OpenFOAM Running, Solving & CFD 3 October 17, 2019 23:27
Need info about totalPressure boundary condition sahmed OpenFOAM Running, Solving & CFD 4 December 4, 2018 22:23
About the totalPressure BC fmerk OpenFOAM Running, Solving & CFD 1 September 25, 2017 18:53
totalPressure boundary :Performance Curve (constant RPM) nash OpenFOAM Running, Solving & CFD 0 September 6, 2013 12:34
Totalpressure Ansys Leuchte CFX 2 April 9, 2013 19:56
