timeVaryingMappedFixedValue problems within rhoCentralFoam for Blasius Solution |
Josh Kelly
Rep Power: 7 ![]() |
I'm trying to simulate viscous flow over a flat plate and use the timeVaryingMappedFixedValue boundary condition to set the inlet velocity to be equal to the velocity profile calculate using the Blasius solution. However, when I use this BC I either get a strange wave that forms at the start of my domain, as can be seen in the image. What can be causing this and how can I eliminate this? I think it may have something to do with a negative initial temperature error I was experiencing when trying to implement the timeVaryingMappedFixedValue BC? Thanks in advance for your help ![]() Last edited by joshkellyjak; December 9, 2019 at 13:00. Reason: forgot to attach image lol |
blasius, boundary condition error, rhocentralfoam;, timevaryingmappedfixedval |
grid dependancy | gueynard a. | Main CFD Forum | 19 | June 27, 2014 21:22 |
Inflation Layers/thickness causing solution convergence problems | kd55 | CFX | 1 | November 13, 2012 20:26 |
Problems with sonicTurbFoam | tangd | OpenFOAM Running, Solving & CFD | 0 | May 29, 2006 09:07 |
Has the pressure correction method problems? | X. Ye | Main CFD Forum | 17 | September 1, 1999 16:14 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 01:16 |
