Marko Josic
Rep Power: 15 ![]() |
Hello Community,
i've ran some simulations with kOmega SST turbulence model in a rotating reference frame. Now i will investigate the compressibility effect and i haven't found an appropriate solver. Actually my case consist only a rotating reference frame, and i don't know which solver is preferable for compressible fluids. greetings, emJay |
Rep Power: 9 ![]() |
Hello emjay,
as far i know foam-extend is the only version providing a compressible SRF solver called steadyCompressibleSRFFoam. If you want to use the foundation version (OFO 5/6/7) or OpenFOAM+ (OFO v1912) you have to modify a solver by yourself. Alternatively you can transform your case to a multi-region (MRF) setup so that you can use rhoSimpleFoam. Last edited by .bastian; January 22, 2020 at 10:59. |
srfsimplefoam |
two mixing compresible fluids solver | ziemowitzima | OpenFOAM Running, Solving & CFD | 27 | August 13, 2020 12:40 |
Mixing of two fluids (mashed potato and pigment-colour), singlephase or multiphase | Zeljko | CFX | 7 | February 23, 2018 07:58 |
Mixing 2 fluids | paul115 | Fluent Multiphase | 1 | May 18, 2015 15:59 |
Differents fluids separated by wall | phil | FLUENT | 0 | January 18, 2007 02:43 |
turbulent mixing of two fluids | ulrich bieder | Main CFD Forum | 2 | October 9, 1999 16:15 |
