cannot use fvOptions vectorCodedSource in parallel simulation
Old   December 5, 2019, 15:44
Default cannot use fvOptions vectorCodedSource in parallel simulation
Sgs
S
Sgs is on a distinguished road
I can run my simulation on 1 core with my fvOptions file, and I can run the simulation in parallel without my fvOptions file, but I cannot run a parallel simulation with my fvOptions file.
Version: OpenFOAM v1806
Solver: icoReactingMultiphaseInterFoam
I was using the default fileModificationSkew of 10 and which gave a "Cannot read (NFS mounted) library error" (log file attached).
I re-compiled OpenFoam with fileModificationSkew set to zero (re: this suggestion) which gave a "couldn't close stdout: Stale file handle" error (log file also attached).
I tried making the dynamicCode directory available before running decomposePar, and that didn't seem to help.
Each step (blockMesh, setFields, etc.) before the solver starts runs fine in any of the above configurations, so I have only attached my fvOptions file.
Any advice would be greatly appreciated.
Sgs is offline   Reply With Quote
Old   September 8, 2020, 05:04
Default I am also stuck with similar problem
KGN
mecbe2002 is on a distinguished road
Did you able to fix it?
mecbe2002 is offline   Reply With Quote
Old   October 13, 2020, 00:18
KGN
I am facing the same issue. Did you able to fix it ?
Old   October 13, 2020, 01:36
Sgs
S
No, I gave up on this and created a new solver where I added the term I wanted to the RHS in UEqn.H.
I wanted a sponge-like term so I defined a new scalar field in createFields.H, used the setFields module to set the term to zero everywhere except where I wanted the sponge, and then added
cmptMultiply(SpongeU,U)
to the RHS of the UEqn.
Unsteady simulation solution files in parallel gunnersnroses SU2 1 December 15, 2015 14:28
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
Parallel Simulation Numeca Fine daxterss Fidelity CFD 6 June 24, 2013 05:52
Engine Simulation in parallel Peter_600 OpenFOAM 0 July 26, 2012 07:02
Parallel Deforming Mesh Simulation Tristan CFX 1 January 28, 2009 18:59
