fvOptions for inner-region thermal tesistance
Old   November 30, 2019, 10:33
Default fvOptions for inner-region thermal tesistance
Mike Jäger
mikejaeger is on a distinguished road
Hi Community,
I have a multi-region (2 solids) case and I use chtMultiRegionSimpleFoam. The one solid region is a bed of spheres with contact surfaces between the spheres (This is why it is one region --> connected because of the contact surfaces).
I want to add at those contact surfaces a thermal resistance (because of roughness).
I already extracted the faceZone of those surfaces. I was searching for an appropriate fvOptions entry, but I did not find such an option for this case.
I think the most similar option is "variableHeatTransfer", but I can't use this. It is only valid for 2 different regions.
Another way is to define every sphere as one region but that will increase my computing time extremely because there are many spheres in the geometry.
I hope someone knows a good solution.
Thanks in advance.
Mike
mikejaeger is offline   Reply With Quote
chtmultiregionfoam, fvoptions, solid, thermal resistance
Thermal conductivity issue Jared1986 CFX 3 March 20, 2014 11:38
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
