MaxCo for airfoil simulation
Old   November 26, 2019, 08:00
Default MaxCo for airfoil simulation
Raffaele
rfiore1 is on a distinguished road
Goodmorning to everyone,
I am doing a simulation of an airfoil in 2D with a Re = 30000 and I have some problems regarding the maxCo because Initially I have set this value around 20 but when I have reduced this value to 10 I have noticed that the solution is very different. I am using a pimpleFoam solver.
Is there a general rule to impose the maxCo value?
thanks
rfiore1 is offline   Reply With Quote
Old   November 28, 2019, 17:46
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
rans, des or les?
please consider to read the forum's guidelines for questions, so that the community can try to help you.
HPE is offline   Reply With Quote
Old   November 29, 2019, 01:09
Bazinga is on a distinguished road
I assume you are talking about the Courant number. Yes, you might need a Courant number of < 1. This way a the fluid does not travel further than your cells within one time step. That is explained in most text books. This is also called the CFL (Courant-Friedrichs-Lewy) condition.
Bazinga is offline   Reply With Quote
Convergence Problem - Transient Simulation gemxx Main CFD Forum 0 July 15, 2018 10:36
Mapping Field Data for Mesh Regions from Another Simulation veterator OpenFOAM Pre-Processing 1 July 10, 2018 06:28
Surface Source - Fixed Temperature? robtheslob FloEFD, FloWorks & FloTHERM 18 May 12, 2017 03:28
Simulation FPEs - turbulence for transient and steady-state? DaveR OpenFOAM Running, Solving & CFD 5 March 5, 2017 16:06
Simulation of high pressure diesel injector - all phases compressible with cavitation fivos CFX 4 July 30, 2015 07:48
