problems with advective bc in LES
Old   November 26, 2019, 07:13
Default problems with advective bc in LES
Jin Zhang
sjlouie91 is on a distinguished road
Dear Foamers,
I am now trying to extract the domain from previous RANS results and use the truncated domain for LES simulation. I used 20 chord as the far field for RANS. Attached is the truncated domain.
The inlet U and p for LES are both mapped from RANS results. in OF, we often define p as ZG for inlet, so is that possible that I defined it as fixed Value?
As the outlet is only 1 chord from the airfoil, so I want to use the convective boundary to avoid reflections. I used advective bc for U. But I don't know how to define p. should I define it as advective too? From my previous simulation, I defined it as ZG, and it showed that the results diverged from outlet.
Can anyone provide some suggestions for these problems? Thanks!!!
Best regards,
Jin
sjlouie91 is offline   Reply With Quote
advective, les, pressure boundary
LES Filtering: how are the small and large scales equations solved? atmcfd Main CFD Forum 38 March 14, 2016 15:52
LES problems Roy AVL FIRE 0 March 6, 2013 21:20
Beginning to work in LES - Suggestions needed atmcfd Main CFD Forum 5 July 20, 2012 23:16
How to conduct transient LES simulation tianrenshui311 FLUENT 0 November 15, 2010 14:21
LES NITA giving divergence problems anindya FLUENT 0 June 20, 2005 08:23
