Tutorial offSetCylinder gives unexpected result |
November 26, 2019, 05:23 |
Jean bon
Rep Power: 10 |
Hello everybody,
I ran the tutorial offSetCylinder with OpenFOAM-7 and I do not understand the results. Without changing any parameter, the solution at the first time step (0.001 s) is given in the attached figure. This could be correct with simpleFoam but I ran pimpleFoam. According to the simulation, the flow crosses the whole domain in 1 ms. This does not depend on the time step (1e-6 yields the same result). If I change the boundary condition on the left from Neumann to Dirichlet on the pressure (P=0), then the flow slowly propagates, which better represents reality. But enforcing two Dirichlet boundary conditions on the pressure and velocity on the same boundary leads to oscillations of both variables. I think this is a numerical issue since enforcing zero Neumann condition on the pressure should not yield a infinitely fast propagation of the flow. Does someone have an idea about this matter ? Thank you |
November 28, 2019, 04:22 |
Jean bon
Rep Power: 10 |
Could the problem be a known mathematical behaviour (that I do not know) ? Indeed, does the use of such boundary conditions lead to a uniform flow in the whole domain because it is the mathematical solultion of the incompressible Navier-Stokes equations ? If so, how to model the development of an incompressible jet flow for instance ? Thank you |
Sandia Flame D OpenFoam tutorial case - bad result? | Brandani | OpenFOAM Programming & Development | 8 | January 18, 2022 14:29 |
[snappyHexMesh] The snappyMultiRegionHeater tutorial does not snap correctly | wildfire230 | OpenFOAM Meshing & Mesh Conversion | 2 | May 10, 2019 07:19 |
Read Result Files or User Defined Result | Aquilaris | ANSYS | 0 | February 9, 2011 06:25 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 04:25 |
Rotor/stator tutorial, and how to... | gilberto | CFX | 5 | January 21, 2002 10:41 |
