interIsoFoam - warnings about isocutFace and quadAreaCoeffs |
November 26, 2019, 04:06 |
surya kaundinya
Rep Power: 9 |
I am running a quasi-DNS simulation of primary atomization of high pressure liquid jet using isoadvection VOF method i.e. interIsoFoam solver. I have a very fine grid in region where I expect the spray to be present and a coarse grid in region surrounding it. At some point in my calculation, I get the following Warnings : From function void Foam::isoCutFace::cutPoints(const pointField&, const scalarField&, Foam::scalar, Foam:ynamicList<Foam::Vector<double> >&) in file fvMatrices/solvers/isoAdvection/isoCutFace/isoCutFace.C at line 667 cutPoints = 3((0.00016 -0.0069 0.00026) (0.00017 -0.0069 0.00026) (0.00018 -0.0069 0.00026)) for pts = 5((0.00016 -0.0069 0.00026) (0.00017 -0.0069 0.00026) (0.00018 -0.0069 0.00026) (0.00018 -0.0069 0.00028) (0.00016 -0.0069 0.00028)), f - f0 = 5(0 9.8122982e-16 1.9624596e-15 -6.711945e-07 -6.711945e-07) and f0 = 8.0308739e-12 --> FOAM Warning : From function void Foam::isoCutFace::quadAreaCoeffs(const Foam:ynamicList<Foam::Vector<double> >&, const Foam:ynamicList<Foam::Vector<double> >&, Foam::scalar&, Foam::scalar&) const in file fvMatrices/solvers/isoAdvection/isoCutFace/isoCutFace.C at line 714 Vertex face was cut at pf1 = 3((0.00016 -0.0069 0.00026) (0.00017 -0.0069 0.00026) (0.00018 -0.0069 0.00026)) Is it because of high gradients in the regions where the cell size abruptly changes? The simulation is quite stable and is running without any error. But I would like to know why do I have these warnings and how to address them. Thanks in advance for the suggestions and help. With regards, Surya. |
June 21, 2020, 21:06 |
InterIsoFoam - warnings
Ndong-Mefane Stephane Boris
Rep Power: 12 |
Hello Surya,
Did you find a way to remove the warnings? Kazunobu |
August 4, 2020, 14:40 |
Hi
Munaf
Rep Power: 7 |
Did you manage to resolve this error as it been three month and i couldn't figure it out
Many thanks in advance |
April 21, 2022, 09:48 |
krishna kant
Rep Power: 10 |
One way to resolve the above issue is to reduce the upper and lower limit for alpha. However, this can compromise the accuracy of the result.
