Help needed with creating composite solid heat transfer case |
November 22, 2019, 08:05 |
Andrew Lindsay
Rep Power: 17 |
OK, so I have managed to create my blockmesh for an axisymmetric case, with multiple regions.
The blockmeshDict is attached. I am now after a step by step tutorial on how to set up the case files for solving a solid only (at this stage) steady state and transient heat transfer case. I have used the attached controlDict file also for generating the mesh. I have also created individual thermophysicalProperties files for each solid region that I can upload also if needed. I have followed the wikipedia example on creating the polymesh file, i.e. reducing the number of regions by 1 and removing the axis of symmetry. A simple schematic of what I am trying to model is shown below. Any assistance with the next steps would be greatly appreciated. Last edited by andrewlindsay; November 22, 2019 at 08:12. Reason: added image link |
No conjugate heat transfer between solid (cast iron) and fluid (water) part | Rajaero | FLUENT | 5 | June 25, 2023 04:07 |
Conjugated heat transfer (CHT): Solid not cooling down | pythag0ra5 | CFX | 3 | August 6, 2017 19:54 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 05:39 |
Porous domain:Interfacial area density and heat transfer coefficient | l.te | CFX | 2 | May 18, 2014 00:45 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
