convergence problem in steady state simulation of centrifugal fan in openfoam
Old   November 22, 2019, 03:35
Default convergence problem in steady state simulation of centrifugal fan in openfoam
rohan majalekar
rohan1495 is on a distinguished road
hello,
I am new to openfoam and trying to simulate centrifugal fan with steady state, in-compressible, turbulent flow(realizableKE model) MRF approach using simpleFoam solver. The problem is solution is not converging(after not 10000 iterations) and values of U & P are in order of 10^3 & 10^9.
Initial & Boundary conditions
1. P
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
Rotar
type zeroGradient;
Inlet
type fixedValue;
value uniform 84104.28;// atm pressure nearly 1 bar
Outlet
type zeroGradient;
Wall
type zeroGradient;
2.U
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
Rotar
type noSlip;
Inlet
type pressureInletVelocity;
value uniform (0 0 0);
Outlet
type flowRateOutletVelocity ;
volumetricFlowRate 0.0452;//=2712 lpm
Wall
type noSlip;
3.epsilon
dimensions [0 2 -3 0 0 0 0];
internalField uniform 5.604;
boundaryField
Rotar
type epsilonWallFunction;
value uniform 5.604;
Wall
Inlet
type fixedValue;
Outlet
type zeroGradient;
4. k
internalField uniform 0.91;
boundaryField
Rotar
type kqRWallFunction;
value uniform 0.91;
Wall
value uniform 0.91;
Inlet
type turbulentIntensityKineticEnergyInlet;
intensity 0.02; //
value uniform 0.91; //
Outlet
type zeroGradient;
5.MRF properties
MRF1
cellZone Fan;
active yes;
// Fixed patches (by default they 'move' with the MRF zone)
nonRotatingPatches ();
origin (0 0 105);
axis (0 0 1);
omega -50;//477rpm
6.fvSchemes
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
divSchemes
default none;
div(phi,U) Gauss upwind;
div(phi,k) Gauss upwind ;
div(phi,epsilon) Gauss upwind ;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
wallDist
method meshWave;
7.fvSolution
solvers
p
solver GAMG;
tolerance 1e-02;
relTol 0.05;
smoother GaussSeidel;
nCellsInCoarsestLevel 20;
U
solver smoothSolver;
nSweeps 2;
tolerance 1e-02;
relTol 0.1;
k
nSweeps 2;
tolerance 1e-02;
relTol 0.1;
epsilon
nSweeps 2;
tolerance 1e-02;
relTol 0.1;
SIMPLE
nNonOrthogonalCorrectors 1;
pRefCell 0;
pRefValue 0;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
k 0.3;
epsilon 0.3;
whether boundary conditions, units, MRF or tubulent model is going wrong??
rohan1495 is offline   Reply With Quote
centrifugal fan, mrfproperties, openfoam, turbulence modelling
Convergence Problem - Transient Simulation gemxx Main CFD Forum 0 July 15, 2018 10:36
Convergence in Transient; Divergence in Steady State artkingjw FLUENT 6 May 24, 2018 03:51
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
Timescale and convergence of steady state simu with CFX Mason liu CFX 7 December 25, 2015 23:12
convergence issues on steady state solver icemaniac178 CFX 1 March 30, 2011 20:11
