November 18, 2019, 10:19 |
DeLaval Nozzle - Temperature increase
Tommaso M.
Rep Power: 8 |
Hi All,
I performed a simulation by using rhoPimpleFoam about an inviscid, laminar flow in a 2D de Laval nozzle (walls are adiabatic). Mesh and results (compared to isentropic calculation) are attached. Mach and pressure profiles along nozzle are correct,but temperature is not! It seems that temperature increases along the cylinder before the nozzle inlet, then it assumes the correct trend inside the nozzle. It looks like T (and rho) is decoupled from the other quantities (p and U). Could anyone help me? Thanks. Tommy |
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 07:36 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 18:00 |
unexpected constant Temperature on a clip surface | Sungki | OpenFOAM Running, Solving & CFD | 0 | August 4, 2015 05:50 |
Momentum loss with temperature increase | siw | CFX | 2 | October 30, 2013 09:10 |
Interface heat or temperature increase | siw | CFX | 1 | October 2, 2013 14:24 |
