Temperature cannot be transferred
Old   November 16, 2019, 07:17
Default Temperature cannot be transferred
909281 is on a distinguished road
Hello everyone,
I'm a novice learning openfoam. I'm doing a heat transfer simulation with openfoam. I set different temperatures on the upper and lower sides of the z-axis. The inside of the hexahedron is full of water, and a small piece of solid is set in the center. But I find that the temperature can't be transmitted. What's the reason?
I would be grateful if you could give me some advice。
909281 is offline   Reply With Quote
Shadow Wall and temperature norger FLUENT 10 September 28, 2019 12:43
heat transfer coefficient value in floefd jason kid FloEFD, FloWorks & FloTHERM 10 October 16, 2016 17:55
UDF for Back-flow Temperature G340 Fluent UDF and Scheme Programming 3 August 21, 2013 05:56
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 07:08
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 18:31
