November 16, 2019, 04:02 |
Error with overInterDyMFoam
Hector Pacheco
Rep Power: 7 |
Hi everyone, I´m trying to run a simulation, however I´m getting this error:
Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: rigidBodyMotion Selecting rigidBodySolver Newmark PIMPLE: no residual control data found. Calculations will employ 3 corrector loops Reading field p_rgh Reading field U Reading/calculating face flux field phi cellVolumeWeight : detected 1 mesh regions zone:0 nCells:136752 Marking patch-cells on zone 0 Marking cells on overset patch oversetPatch Marking cells on proper patch atmosphere with type patch Marking cells on proper patch inlet with type patch Marking cells on proper patch outlet with type patch Marking cells on overset patch oversetAll Marking cells on proper patch hull with type wall After patch analysis : nCells : 136752 other : 127766 patch : 7294 overset: 1692 cellVolumeWeight : detected 3 mesh regions after overset Mark region:2 on zone:0 as next to blockage at0.5 -0.5 -1.93777) Proper patch atmosphere of type patch reachable region : 0 at cell (-25.5 -18.5 3.8806) on zone 0 Proper patch inlet of type patch Proper patch outlet of type patch Proper patch hull of type wall reachable region : 2 at cell (0.552539 -0.525906 0.0104635) on zone 0 Storing faces on patch oversetPatch Storing faces on patch oversetAll Front : fraction:1 size:3388 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigSegv::sigHandler(int) at ??:? #2 ? in /lib64/libc.so.6 #3 ? in /lib64/libc.so.6 Anyone can help me? Thanks in advance |
[waves2Foam] Trying to integrate waves2Foam with overInterDyMFoam | blaise | OpenFOAM Community Contributions | 13 | November 22, 2023 06:21 |
overInterDyMFoam crash in parallel - solution singularity | Swift | OpenFOAM Running, Solving & CFD | 1 | December 27, 2022 00:27 |
overInterDyMFoam case - stability | ginop | OpenFOAM Running, Solving & CFD | 0 | August 2, 2018 21:02 |
overInterDyMFoam mass default | mojuss | OpenFOAM Running, Solving & CFD | 1 | February 2, 2018 11:48 |
Mass conservation error overInterDyMFoam (OF v.1706) | ngj | OpenFOAM Bugs | 6 | July 19, 2017 15:15 |
