twoPhaseEulerFoam with phase change
Old   November 15, 2019, 20:14
Default twoPhaseEulerFoam with phase change
Stanley John
sjohn2 is on a distinguished road
I am simulating non equilibrium flashing of water into steam and I need to use euler-euler method namely twoPhaseEulerFoam with phase change. The original version does not have phase change implemented and I need to implement as source terms.
Does anyone has any links for thesis, papers - ideally with some sort of code given to implement the phase change. Mainly I would need the saturation pressures at a given temperature and vice versa for water/steam.
Any help is appreciated.
Stanley
sjohn2 is offline   Reply With Quote
Old   November 16, 2019, 10:55
Joachim Herb
jherb is on a distinguished road
Have a look at reactingTwoPhaseEulerFoam. There are several tutorials with respect to boiling:
https://github.com/OpenFOAM/OpenFOAM...eEulerFoam/RAS
jherb is offline   Reply With Quote
Old   November 18, 2019, 22:29
Default Thanks
Stanley John
Thank you buddy. I was probably looking at the wrong direction.
It seems that phase change is built in the solver. I normally like to setup the solver in an integrated development environment like qt creator, study the equations and look what I need to modify. I am doing my PhD on flashing of steam.
Just to confirm the twoPhaseEulerFoam is not the right solver and and reactingTwoPhaseEulerFoam is the correct one, just from the point of view that phase change models are built in reactingtwophaseeulerfoam and not in twophaseeulerfoam.
Stanley
Custom Lagrangian Phase Change Model craven.brent OpenFOAM Programming & Development 4 December 25, 2022 20:22
Multiphase solvers and non-isothermal phase change erlend_grotle OpenFOAM 1 September 25, 2021 10:48
Phase Change >> which solver ? >> met a problem I can't solve, please help me with it Kummi OpenFOAM Programming & Development 6 September 8, 2021 05:58
Need help regarding phase change models in ansys fluent diggee Fluent Multiphase 0 October 11, 2016 12:35
Change phase phenomena Imane FLUENT 0 May 4, 2016 16:56
