Multiphase with permeability to air and not to Water
Old   November 14, 2019, 13:50
Default Multiphase with permeability to air and not to Water
JS1970 is on a distinguished road
Dear OpenFoamers,
I've started recently to work with OpenFoam and was going quite well, but then I found a problem which I can't find the right answer:
- It's a case of multiphase with water and air. It's a transient situation, where water enters the inlet, and has several outlets, but some of them block the exit of water, since they are a physical barrier, but are permeable to air.
- Is there a way to define an outlet where only air can exit, but not water?
I've looked around and could not find such a situation defined. The standard BC that I found define several cases but nothing similar with this.
May be someone has a good suggestion.
Thank you.
JS1970 is offline   Reply With Quote
Old   August 26, 2020, 08:48
Laurien Vandewalle
lavdwall is on a distinguished road
Did you find a solution to this problem?
lavdwall is offline   Reply With Quote
Old   August 27, 2020, 16:23
Unfortunately not until now. I found that more people needs that and found other places but nobody did answer it really.
The only possible solution I could find mentioned was to use swak4foam and write some equation which changes with "alpha", but I´m not sure how to do it and it will really work.
boundary condition, multiphase, permeability
