2D nozzle exhausting to Farfield - FP error with rhoSimpleFoam |
November 11, 2019, 00:13 |
Mike
Rep Power: 9 |
I'm trying to setup a 2D nozzle simulation exhausting over a coanda surface into a farfield, using the rhoSimpleFoam solver (laminar, standard day air). I can get the simulation to run, but it will diverge after a few iterations and return a floating point error. My mesh isn't perfect, but it does pass all the default mesh checks. I've set the pressure boundary conditions as totalPressure at the inlet and fixedValue at the outlet, and set the velocity BCs as zeroGradient. Temperature is fixedValue at the inlet and zeroGradient at the outlet. I was wondering if anybody had any idea what I've done wrong?
transsonic nozzle with rhoSimpleFoam | Unseen | OpenFOAM Running, Solving & CFD | 8 | July 1, 2022 07:54 |
compressible, rhoSimpleFoam, multi-species, steady state, rocket nozzle | David_C | OpenFOAM Running, Solving & CFD | 1 | April 18, 2017 12:01 |
Help needed to setup CD nozzle exhausting to atmosphere | sangrampp | FLUENT | 10 | January 27, 2011 12:06 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 02:45 |
