problem with saving data
Old   November 8, 2019, 06:42
Default problem with saving data
Przemek
gaza is on a distinguished road
Hi
I calculate tasks on supercomputer. I get very often the error that OF
cannot save data for the time I prescribed in controlDict.
For instance recently I got:
[wn0258:173865] *** Process received signal ***
[wn0258:173867] *** Process received signal ***
[wn0258:173867] Signal: Bus error (7)
[wn0258:173867] Signal code: Non-existant physical address (2)
[wn0258:173867] Failing at address: 0x49cda0
[wn0258:173868] *** Process received signal ***
[wn0258:173868] Signal: Bus error (7)
[wn0258:173868] Signal code: Non-existant physical address (2)
[wn0258:173868] Failing at address: 0x49cda0
[wn0258:173869] *** Process received signal ***
[wn0258:173869] Signal: Bus error (7)
[wn0258:173869] Signal code: Non-existant physical address (2)
[wn0258:173869] Failing at address: 0x49cda0
[wn0258:173870] *** Process received signal ***
Does anybody know what could be the reason?
best regards
pblasiak
gaza is offline   Reply With Quote
Moving boundary problem based on calculated data sandro.grm OpenFOAM Programming & Development 53 October 11, 2024 09:50
UDF value to large for defined data type Anna73 Fluent UDF and Scheme Programming 9 September 30, 2018 23:18
saving monitoring data mange FLUENT 2 March 3, 2009 06:54
IFStream read float point data problem liu OpenFOAM Running, Solving & CFD 0 October 24, 2008 13:14
Saving particle (DPM) data to file? Philip FLUENT 2 June 12, 2006 02:41
