rhoPimpleAdiabaticAcousticFoam
Old   November 7, 2019, 01:56
Default rhoPimpleAdiabaticAcousticFoam
Brett
Bdew8556 is on a distinguished road
Hi all,
I've been following the Chalmers paper on implementing an aeroacoustic solver.
I'm getting close but I come up with this error. Anyone have any ideas???
g++ -std=c++11 -m64 -DOPENFOAM=1906 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -Wno-unknown-pragmas -O3 -DNoRepository -ftemplate-depth-100 -I/opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/cfdTools -I/opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/meshTools/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/sampling/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/transportModels/compressible/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/thermophysicalModels/basic/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/TurbulenceModels/turbulenceModels/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/TurbulenceModels/compressible/lnInclude -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1906/src/OSspecific/POSIX/lnInclude -fPIC -c rhoPimpleAdiabaticAcousticFoam.C -o /opt/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/applications/solvers/compressible/rhoPimpleAdiabaticAcousticFoam/rhoPimpleAdiabaticAcousticFoam.o
In file included from ./createFields.H:1:0,
from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/postProcess.H:133,
from rhoPimpleAdiabaticAcousticFoam.C:68:
/opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createRDeltaT.H: In function ‘int main(int, char**)’:
/opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createRDeltaT.H:1:16: error: ‘Foam::fv::localEulerDdt’ has not been declared
bool LTS = fv::localEulerDdt::enabled(mesh);
/opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createRDeltaT.H:15:17: error: ‘localEulerDdt’ is not a member of ‘Foam::fv’
fv::localEulerDdt::rDeltaTName,
In file included from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/postProcess.H:133:0,
./createFields.H:105:36: error: ‘dimensionsScalar’ was not declared in this scope
dimensionsScalar(p.dimensions())
./createFields.H:188:1: warning: ‘Foam::dimensioned<Type>::dimensioned(const Foam::word&, const Foam::dimensionSet&, Foam::Istream&) [with Type = double]’ is deprecated: Since 2018-11 [-Wdeprecated-declarations]
In file included from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedType.H:534:0,
from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedScalar.H:40,
from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/TimeState.H:40,
from /opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/Time.H:49,
from /opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/fvCFD.H:6,
from rhoPimpleAdiabaticAcousticFoam.C:47:
/opt/OpenFOAM/OpenFOAM-v1906/src/OpenFOAM/lnInclude/dimensionedType.C:258:1: note: declared here
./createFields.H:195:1: warning: ‘Foam::dimensioned<Type>::dimensioned(const Foam::word&, const Foam::dimensionSet&, Foam::Istream&) [with Type = double]’ is deprecated: Since 2018-11 [-Wdeprecated-declarations]
./createFields.H:165:8: warning: unused variable ‘timeIndex’ [-Wunused-variable]
scalar timeIndex = 1;
In file included from createFields.H:1:0,
from rhoPimpleAdiabaticAcousticFoam.C:77:
In file included from rhoPimpleAdiabaticAcousticFoam.C:77:0:
In file included from rhoPimpleAdiabaticAcousticFoam.C:78:0:
/opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createFvOptions.H:1:37: error: redeclaration of ‘Foam::fv:ptions& fvOptions’
fv:ptions& fvOptions(fv:ptions::New(mesh));
In file included from createFields.H:207:0,
/opt/OpenFOAM/OpenFOAM-v1906/src/finiteVolume/lnInclude/createFvOptions.H:1:14: note: ‘Foam::fv:ptions& fvOptions’ previously declared here
In file included from rhoPimpleAdiabaticAcousticFoam.C:124:0:
acousticSolver.H:4:16: warning: suggest parentheses around assignment used as truth value [-Wparentheses]
if(timeIndex=1)
/opt/OpenFOAM/OpenFOAM-v1906/wmake/rules/General/transform:34: recipe for target '/opt/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/applications/solvers/compressible/rhoPimpleAdiabaticAcousticFoam/rhoPimpleAdiabaticAcousticFoam.o' failed
make: *** [/opt/OpenFOAM/OpenFOAM-v1906/build/linux64Gcc63DPInt32Opt/applications/solvers/compressible/rhoPimpleAdiabaticAcousticFoam/rhoPimpleAdiabaticAcousticFoam.o] Error 1
Bdew8556 is offline   Reply With Quote
aeroacoustics, compilation error, euler equations, openfoam 1806
