November 4, 2019, 04:19 |
solids4foam
Torsten Schenkel
Rep Power: 12 |
This post was also posted to the OpenFOAM CC Toolkits for Fluid-Structure Interaction board, as it fits there better. Apologies for double post.
Hi, I am in the process of migrating my FSI simulations from the old FSI toolbox to the new solids4foams. I am currently running Using: foam-extend-4.1 (see www.foam-extend.org) Build: 4.1-5832cfe256a5 When I try to run the 3dTube/linearElastic3dTube tutorial case the case runs fine, however, paraview can't read the solid region: ...Error reading line 11260 of /home/acests3/foam/acests3-4.1/run/3dTube/linearElastic3dTube/0.0002/solid/D: Found duplicated entries with keyword value ...Error reading line 8052 of /home/acests3/foam/acests3-4.1/run/3dTube/linearElastic3dTube/0.0002/solid/D_0: Found duplicated entries with keyword value ...Error reading line 44 of /home/acests3/foam/acests3-4.1/run/3dTube/linearElastic3dTube/0.0002/solid/D_0_0: Found duplicated entries with keyword value Paraview is V5.6.0 What am I missing? Best Torsten |
solids4foam |
InterFace mismatch in solids4Foam toolkit for HronTurekFSI3 | thegauravonline | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 27 | September 17, 2024 13:55 |
pimpleFoam is right, how about solids4Foam pimpleFluid? | amuzeshi | OpenFOAM Running, Solving & CFD | 6 | December 9, 2019 11:55 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 13:50 |
Fatal error in solids4Foam | brunomramoa | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 1 | October 16, 2019 13:26 |
[FSI] solids4Foam vs icoFsiElasticNonLinULSolidFoam on HPC server | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 7 | August 31, 2019 06:26 |
