November 1, 2019, 14:41 |
Pipe Flow- Comparison Fluent-OpenFoam
Fab
Rep Power: 8 |
Dear all,
I run my case (pipe flow with mass flow at intlet and pressure outlet) both in Fluent and in OpenFoam. The BCs are the following: Inlet: massflow=0.11kg/s Outlet Pressure outlet Fluid: water Operating Pressure: 1 bar Fluent: steady state, pressure based solver, standard setup for numeric. OpenFoam: icoFoam with kinematic viscosity for water Same mesh has been used for comparison reason. The inlet is placed upstream with a semi-spherical shape. Results: Pressure at inlet: a) Fluent :about 5 bar b) OpenFoam: about 2.4 bar Any idea why the OpenFoam is not matching the fluent result? Many thanks in advance. |
November 1, 2019, 15:11 |
Rep Power: 21 |
Since you are not giving any information....my best guess is....because you did something wrong.
You are using icoFoam, hence this must be laminar flow. For laminar flow in a pipe there is an analytic solution. Which software is closer to the truth? A Reynoldsnumber, diameter, the actual boundary conditions used etc, a case etc, might be needed to find that error. |
November 1, 2019, 15:18 |
Fab
Rep Power: 8 |
Sorry i was using simpleFoam. It is a turbulent flow. Pipe Diameter 2mm
November 4, 2019, 02:22 |
Ruiyan Chen
Rep Power: 10 |
Are you running RANS? Which turbulence model are you using in both solvers?
As pointed out by others, you can estimate the pressure drop along the pipe. For turbulent flow you can use the Moody diagram I guess. |
November 4, 2019, 05:12 |
Gerhard Holzinger
Rep Power: 28 |
Depending on the choice of turbulence model, you can get pressure-differences that are way off, if you get y+ wrong. The OP provides too little information for any further discussion/suggestions.
Comparison between OpenFOAM and FLUENT: capabilities | Time4Tea | OpenFOAM | 2 | November 5, 2018 14:11 |
Multiphase flow in a pipe with a CHT | wissal | CFX | 4 | June 12, 2017 13:15 |
Modelling Slug Flow in ANSYS Fluent VOF. | OliverMechEng2208 | Fluent Multiphase | 1 | March 18, 2015 06:45 |
Different flow patterns in CFX and Fluent | avi@lpsc | FLUENT | 4 | April 8, 2012 07:12 |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 09:36 |
