Ratating boundary condition querry
Old   November 1, 2019, 14:21
Default Ratating boundary condition querry
Deepanker Chaudhary
ShanuNith is on a distinguished road
Hi everyone,
I have a doubt in my mind, how do i know the axis direction of my rotating cylinder.
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
leftWall
type noSlip;
rightWall
type noSlip;
lowerWall
type noSlip;
atmosphere
type pressureInletOutletVelocity;
value uniform (0 0 0);
cylinder1Wall
type rotatingWallVelocity;
origin (-0.035 0 -1);
axis (0 0 1);
omega constant -2; //rad per sec
cylinder2Wall
origin (0.035 0 1);
axis (0 0 1);
omega constant 2; //rad per sec
defaultFaces
type empty;
i have two cylinders of which the first cylinder is at left and second is at right. Left one is to be rotated in clockwise directiln while the right on is to be roated in counter-clockwise direction such that a converging velocity field is made in between the cylinders. but i am not sure how to define the direction because i exactly dont know what (0 0 1) represtns in front of axis. and what if its is (0 0 -1)
I am really confused.
ShanuNith is offline   Reply With Quote
Old   November 1, 2019, 15:23
Bloerb will become famous soon enough
origin is the point around which you are rotating. A point alone is however not enough to define a rotation. The axis is the axis around which you are rotating. (0 0 1) means you are rotating around the z axis. For a 2D calculation in the x-y plane this would be the logical choice. The speed at which you are rotating is omega.
Hence your rotation vector is (0 0 1*omega). a positive value of omega now means that you are rotating in a mathematically positive direction (counter-clock-wise). You could either reverse the axis (0 0 -1) to change the direction, or simply define omega as a negative number. Axis is normalized. So (0 0 2) is the same as (0 0 1).
Bloerb is offline   Reply With Quote
Old   November 2, 2019, 16:22
Deepanker Chaudhary
Thanks a lot for quick and elaborate explanation.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Radiation interface hinca CFX 15 January 26, 2014 18:11
