natural convection in square cavity having inlet and outlet |
October 31, 2019, 00:26 |
sujeet toppo
Rep Power: 7 |
I'm trying to run natural convection having one inlet, one outlet and one isothermal wall. having difficulty for the U parameter. I'm attaching the boundary condition file. please help me as it is for my college project and i'm new to openfoam. i'm using buoyantsimplefoam for the solver. for U i have to give the internal field value or else the solver get failed.
blockMesh file. convertToMeters 1; vertices ( (0 0 0) //0 (4 0 0) //1 (0 1 0) //2 (4 1 0) //3 (0 4 0) //4 (4 4 0) //5 (0 5 0) //6 (4 5 0) //7 (0 0 1) //8 (4 0 1) //9 (0 1 1) //10 (4 1 1) //11 (0 4 1) //12 (4 4 1) //13 (0 5 1) //14 (4 5 1) //15 ); blocks ( hex (0 1 3 2 8 9 11 10) (40 10 1) simpleGrading (1 1 1) hex (2 3 5 4 10 11 13 12) (40 30 1) simpleGrading (1 1 1) hex (4 5 7 6 12 13 15 14) (40 10 1) simpleGrading (1 1 1) ); edges ( ); boundary ( top { type wall; faces ( (6 14 15 7) ); } isothermal { type wall; faces ( (0 1 9 8) ); } inlet { type patch; faces ( (0 8 10 2) ); } outlet { type patch; faces ( (5 7 15 13) ); } rightSidewall { type wall; faces ( (2 10 12 4) (4 12 14 6) ); } sidewall { type wall; faces ( (1 3 11 9) (3 5 13 11) ); } ); mergePatchPairs ( ); ALPHA FILE. dimensions [1 -1 -1 0 0 0 0]; internalField uniform 0; boundaryField { top { type compressible::alphatJayatillekeWallFunction; Prt 0.71; value $internalField; } isothermal { type compressible::alphatJayatillekeWallFunction; Prt 0.71; value $internalField; } inlet { type fixedValue; value $internalField; } outlet { type zeroGradient; } rightSidewall { type compressible::alphatJayatillekeWallFunction; Prt 0.71; value $internalField; } sidewall { type compressible::alphatJayatillekeWallFunction; Prt 0.71; value $internalField; } frontandback { type empty; } } EPSILON FILE. dimensions [0 2 -3 0 0 0 0]; internalField uniform 4.312e-4; boundaryField { top { type epsilonWallFunction; value uniform 4.312e-4; } isothermal { type epsilonWallFunction; value uniform 4.312e-4; } inlet { type fixedValue; value uniform 4.312e-4; } outlet { type zeroGradient; } rightSidewall { type epsilonWallFunction; value uniform 4.312e-4; } sidewall { type epsilonWallFunction; value uniform 4.312e-4; } frontandback { type empty; } } K FILE. dimensions [0 2 -2 0 0 0 0]; internalField uniform 0.015; boundaryField { top { type kqRWallFunction; value uniform 0.015; } isothermal { type kqRWallFunction; value uniform 0.015; } inlet { type fixedValue; value uniform 0.015; } outlet { type zeroGradient; } rightSidewall { type kqRWallFunction; value uniform 0.015; } sidewall { type kqRWallFunction; value uniform 0.015; } frontandback { type empty; } } NUT FILE. dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { top { type nutkWallFunction; value uniform 0; } isothermal { type nutkWallFunction; value uniform 0; } inlet { type calculated; value uniform 0; } outlet { type zeroGradient; } rightSidewall { type nutkWallFunction; value uniform 0; } sidewall { type nutkWallFunction; value uniform 0; } frontandback { type empty; } } P FILE. dimensions [1 -1 -2 0 0 0 0]; internalField uniform 101325; boundaryField { top { type zeroGradient; } isothermal { type zeroGradient; } inlet { type zeroGradient; } outlet { type zeroGradient; } rightSidewall { type zeroGradient; } sidewall { type zeroGradient; } frontandback { type empty; } } P_RGH FILE. dimensions [1 -1 -2 0 0 0 0]; internalField uniform 0; boundaryField { top { type fixedFluxPressure; value uniform 0; } isothermal { type fixedFluxPressure; value uniform 0; } inlet { type fixedFluxPressure; value uniform 0; } outlet { type zeroGradient; } rightSidewall { type fixedFluxPressure; value uniform 0; } sidewall { type fixedFluxPressure; value uniform 0; } frontandback { type empty; } T FILE internalField uniform 300; boundaryField { top { type fixedValue; value $internalField; } isothermal { type fixedValue; value uniform 400; } inlet { type fixedValue; value uniform 300; } outlet { type zeroGradient; } rightSidewall { type fixedValue; value $internalField; } sidewall { type fixedValue; value $internalField; } frontandback { type empty; } } U FILE. dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.5 0 0); boundaryField { top { type noSlip; } isothermal { type noSlip; } inlet { type inletOutlet; inletValue uniform (0.5 0 0); value $internalField; } outlet { type zeroGradient; } rightSidewall { type noSlip; } sidewall { type noSlip; } frontandback { type empty; } } |
November 2, 2019, 03:17 |
sujeet toppo
Rep Power: 7 |
Hey anyone find the solution for my problem. Please rply as im waiting for it.
inlet outlet, natural convection, square cavity |
Want Impeller Driven Fluid Flow: What Inlet and Outlet BC to use for Centrifugal Pump | Zev Xavier | FLUENT | 3 | May 9, 2016 07:42 |
Pressure inlet vs outlet position, transient, time dependent pressure and gravity | silent2608 | FLUENT | 0 | February 6, 2016 11:19 |
CFX Simple valve model, inlet and outlet conditions | 749604 | CFX | 24 | August 11, 2014 19:51 |
UDF profile: Fluent method for coupling inlet and outlet | I-mech | Fluent UDF and Scheme Programming | 0 | May 10, 2014 11:36 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 07:52 |
