CHTMultyRegionFoam - BC problem?
Old   October 30, 2019, 09:54
Default CHTMultyRegionFoam - BC problem?
Carlo_P
Carlo_P is on a distinguished road
Hey Guys,
I'm trying to perform and analys with CHTMultyRegionFoam.
A liquid is inside a mold and the mold is heater by some resistance.
I tried to set up, I run it, but some errors appers.
I attach the folder. Can you take a look and give me some suggestions?
I think that the problem is linked to some BL
Thanks a lot,
Carlo
Error, during the first iteration, after rho, Ux,Uy,Uz and h calcolation
--> FOAM FATAL ERROR:
Maximum number of iterations exceeded: 100
    From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scal                          ar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type                          >::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<The                          rmo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::t                          hermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstTh                          ermo<Foam::rhoConst<Foam::specie> >; Type = Foam::sensibleEnthalpy; Foam::scalar                           = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hCo                          nstThermo<Foam::rhoConst<Foam::specie> >, Foam::sensibleEnthalpy>]
    in file /opt/CFDSupportFOAM4.0/beta/OpenFOAM-dev/src/thermophysicalModels/sp                          ecie/lnInclude/thermoI.H at line 73.
FOAM aborting
solid/T
|  \\    /   O peration     | Version:  dev                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0/metal";
    object      T;
dimensions      [ 0 0 0 1 0 0 0 ];
internalField   uniform 400;
boundaryField
     Box
        type            zeroGradient;
    "Res.*"
        type            fixedValue;
        value uniform 480;
        Fronte
        type            externalWallHeatFluxTemperature;
        kappaMethod     solidThermo;
        //thicknessLayers ();
        //kappaLayers     ();
        mode            coefficient;
        h               uniform 8;
        Ta              290;
        value           290;
        Retro
        thicknessLayers ();
        kappaLayers     ();
        mode            coefficient;
        h               uniform 8;
        Ta              290;
        value           290;
    Inlet1
        thicknessLayers ();
        kappaLayers     ();
        mode            coefficient;
        h               uniform 8;
        Ta              290;
        value           290;
        Inlet2
        thicknessLayers ();
        kappaLayers     ();
        mode            coefficient;
        h               uniform 8;
        Ta              290;
        value           290;
    Outlet1
        thicknessLayers ();
        kappaLayers     ();
        mode            coefficient;
        h               uniform 8;
        Ta              290;
        value           290;
    Outlet2
        thicknessLayers ();
        kappaLayers     ();
        mode            coefficient;
        h               uniform 8;
        Ta              290;
        value           290;
    domain0_to_Fluido
    type            compressible::turbulentTemperatureCoupledBaffleMixed;
    value           uniform 300;
    Tnbr            T;
    kappaName       none;
solid/p
FoamFile
    version     2.0;
    format      ascii;
    location    "0/heater";
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 101325;
boundaryField
        type            calculated;
        value           $internalField;
fluid/T
FoamFile
    version     2.0;
    format      ascii;
    location    "0/fluid";
    object      T;
internalField   uniform 0;
boundaryField
 "Inlet."
        kappaMethod     fluidThermo;
        thicknessLayers ();
        kappaLayers     ();
        mode            coefficient;
        h               uniform 8;
        Ta              290;
        value           400;
  "Outlet.*"
        thicknessLayers ();
        kappaLayers     ();
        mode            coefficient;
        h               uniform 8;
        Ta              290;
        value           400;
    Fluido_to_domain0
    value           uniform 300;
    Tnbr            T;
    kappaName       none;
    Fronte
        thicknessLayers ();
        kappaLayers     ();
        mode            coefficient;
        h               uniform 8;
        Ta              290;
        value           400;
    Retro
        thicknessLayers ();
        kappaLayers     ();
        mode            coefficient;
        h               uniform 8;
        Ta              290;
        value           400;
fluid/U
|* OpenFOAM for Windows 18.06 (v1)                                           *|
|* Built by CFD Support, www.cfdsupport.com (based on Symscape).             *|
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "1060";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
 "Inlet."
      type            flowRateInletVelocity;
              massFlowRate    constant 0.0003;
              rhoInlet        1000;
  "Outlet.*"
         type zeroGradient;
        Fluido_to_domain0
        type            fixedValue;
        value           uniform (0 0 0);
    Fronte
        type            fixedValue;
    Retro
         type            fixedValue;
fluid/p_rgh
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      p_rgh;
boundaryField
    "Inlet."
         type            calculated;
         value         101325;
  "Outlet.*"
       type            calculated;
       value         101325;
    Fluido_to_domain0
        type            calculated;
        value         101325;
    Fronte
         type            calculated;
         value         101325;
    Retro
       type            calculated;
       value         101325;
fluid/p
FoamFile
    version     2.0;
    format      ascii;
    location    "0/fluid";
    object      p;
dimensions      [ 1 -1 -2 0 0 0 0 ];
boundaryField
 "Inlet."
        type zeroGradient;
  "Outlet.*"
        type            totalPressure;
        p0              uniform 101325;
        U               U;
        phi             phi;
        rho             rho;
        //psi             none;
        //gamma           1;
        value           uniform 101325;
    Fluido_to_domain0
        type            calculated;
    Fronte
        type zeroGradient;
    Retro
        type zeroGradient;
Carlo_P is offline   Reply With Quote
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 06:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
