Apply heat sink/mimic heat exchanger in closed loop with buoyantBoussinesqPimpleFoam
Old   October 28, 2019, 14:38
Default Apply heat sink/mimic heat exchanger in closed loop with buoyantBoussinesqPimpleFoam
Alex Pressley
alex1001 is on a distinguished road
Hello all,
I am looking for a way to simulate the removal of a certain amount of thermal power from one side of a loop using the buoyantBoussinesqPimpleFoam solver.
The loop represents a segment of the larger system, with one side featuring a heat source and the other representing a heat exchanger and pump (already modelled using a momentum source on a defined cellzone in the loop).
Currently the power removal is modelled by excluding most of the heat exchanger side of the loop, and using inlet and outlet boundary conditions on patches to simulate the heat removal by defining inlet temperature. This is rather crude, and can cause some problems in other, coupled, simulations.
How can I introduce the heat sink more elegantly and using the closed loop?
Many thanks,
Alex
alex1001 is offline   Reply With Quote
buoyantboussinesq, buoyantboussinesqpimple, heat exchanger model, heat sink
Heat transfer analysis of heat exchanger with complicated shape and irregular fins Mahesh Patil CFX 1 September 29, 2016 13:07
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Define a Counterflow heat exchanger in FloEFD Kylbalsam FloEFD, FloWorks & FloTHERM 1 August 16, 2016 09:46
Simulation flow loop of Heat exchanger lalolala FLUENT 1 November 22, 2012 00:53
Heat Exchanger Simulation tightaznbreaka FLUENT 0 March 18, 2010 16:45
