Is it possible to run 'reactingParcelFilmFoam' different way?
Old   October 21, 2019, 15:38
Question Is it possible to run 'reactingParcelFilmFoam' different way?
Ash Kotwal
Ash Kot is on a distinguished road
I'm modifying 'rivulatePanel' case under 'reactingParcelFilmFoam' as per my requirements.
As per the original case, the first step is to modify the geometry/mesh, generate the thin layer as extrusion for wall boundary patch field. Then simulate the case.
I'm thinking of no modification of my geometry/mesh and simulate the case although I will generate the topoSet for the wall film region but won't extrude the mesh, and generate the reaction based thin layer on the desired wall patch fields.
Is it possible to do that?
Ash Kot is offline   Reply With Quote
Old   October 25, 2019, 17:58
Ash Kotwal
Anyone, essentially I'm thinking that instead of making that separate patch of geometry, why not to simulate the entire geometry, while the rivulet flow like structure is being generated over period of simulation on walls.
reactingparcelfilmfoam, rivuletpanel
fatal overflow error in the FINMES subroutine for CHT run prashant79_ss CFX 5 September 27, 2014 05:54
Cannot run phoenix on linux opensuse 13.1 kde mabal Phoenics 0 June 15, 2014 07:16
[mesh manipulation] Cannot get refineMesh to run in parallel smschnob OpenFOAM Meshing & Mesh Conversion 2 June 3, 2014 12:20
First Parallel Run - need some help Gian Maria OpenFOAM 3 June 17, 2011 13:08
Windows 64-bit, Distributed Parallel Run Issues... Erich CFX 3 March 28, 2006 17:36
