rhoPimpleFoam error
Old   October 14, 2019, 18:33
Default rhoPimpleFoam error
anonymous
tenichols19 is on a distinguished road
Hi I'm running a simulation based off the compressible angled duct tutorial opt/openfoam/tutorial/compressible/rhoPimpleFoam/RAS and after I run my simulation I get this error after it runs for a little bit.
I'm going to go back and do my best to check boundary conditions and such but I'm having trouble interpreting what the error is.. Can anyone shed some light on what is going on? Or how to pin point where the issue is?
PIMPLE: Iteration 1
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 1.00633e-06, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 6.60958e-08, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 9.32762e-07, No Iterations 1
smoothSolver:  Solving for e, Initial residual = 1.88026e-05, Final residual = 1.66735e-05, No Iterations 1000
DICPCG:  Solving for p, Initial residual = 1, Final residual = 8.08526e-08, No Iterations 36
pressureControl: p max 111312
diagonal:  Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 1, global = 1, cumulative = 1
smoothSolver:  Solving for epsilon, Initial residual = 0.0592555, Final residual = 0.00422045, No Iterations 3
bounding epsilon, min: -3.03429e+06 max: 5.95861e+09 average: 5.73871e+07
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.00379042, No Iterations 1
PIMPLE: Iteration 2
smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0648606, No Iterations 3
smoothSolver:  Solving for Uy, Initial residual = 0.728353, Final residual = 0.0291832, No Iterations 2
smoothSolver:  Solving for Uz, Initial residual = 1, Final residual = 0.0682855, No Iterations 3
smoothSolver:  Solving for e, Initial residual = 1, Final residual = 0.0912548, No Iterations 2
DICPCG:  Solving for p, Initial residual = 1, Final residual = 8.73524e-08, No Iterations 351
pressureControl: p max 1.34117e+10
time step continuity errors : sum local = 1, global = 1, cumulative = 2
smoothSolver:  Solving for epsilon, Initial residual = 0.00103145, Final residual = 3.97863e-05, No Iterations 2
bounding epsilon, min: -1.03555e+14 max: 1.75415e+18 average: 4.29224e+16
smoothSolver:  Solving for k, Initial residual = 0.18778, Final residual = 0.0125959, No Iterations 1
PIMPLE: Iteration 3
smoothSolver:  Solving for Ux, Initial residual = 0.000738524, Final residual = 4.67996e-05, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 6.19699e-05, Final residual = 3.1511e-06, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.00113877, Final residual = 6.69982e-05, No Iterations 1
smoothSolver:  Solving for e, Initial residual = 0.0459777, Final residual = 0.00275765, No Iterations 1
DICPCG:  Solving for p, Initial residual = 1, Final residual = 5.21854e-08, No Iterations 9
pressureControl: p max 1.10319e+11
time step continuity errors : sum local = 1, global = 1, cumulative = 3
smoothSolver:  Solving for epsilon, Initial residual = 0.000701229, Final residual = 1.91923e-05, No Iterations 2
bounding epsilon, min: -4.30382e+17 max: 8.88497e+19 average: 1.01591e+18
smoothSolver:  Solving for k, Initial residual = 0.335667, Final residual = 0.029473, No Iterations 1
PIMPLE: Iteration 4
smoothSolver:  Solving for Ux, Initial residual = 0.0134738, Final residual = 0.000197854, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.000512107, Final residual = 2.11432e-05, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.16274, Final residual = 0.00241396, No Iterations 1
smoothSolver:  Solving for e, Initial residual = 0.0215283, Final residual = 0.00157497, No Iterations 1
[7] #0  Foam::error::printStack(Foam::Ostream&) at ??:?
[7] #1  Foam::sigFpe::sigHandler(int) at ??:?
[7] #2  ? in "/lib/x86_64-linux-gnu/libc.so.6"
[7] #3  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:?
[7] #4  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:?
[7] #5  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
[7] #6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[7] #7  ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/rhoPimpleFoam"
[taylor-Precision-T1700:31634] *** Process received signal ***
[taylor-Precision-T1700:31634] Signal: Floating point exception (8)
[taylor-Precision-T1700:31634] Signal code:  (-6)
[taylor-Precision-T1700:31634] Failing at address: 0x3e800007b92
[taylor-Precision-T1700:31634] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fd0d5ef5f20]
[taylor-Precision-T1700:31634] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7fd0d5ef5e97]
[taylor-Precision-T1700:31634] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7fd0d5ef5f20]
[taylor-Precision-T1700:31634] [ 3] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x1e2)[0x7fd0dbfe6b02]
[taylor-Precision-T1700:31634] [ 4] /opt/openfoam7/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x7fd0dc01c58a]
[taylor-Precision-T1700:31634] [ 5] rhoPimpleFoam(+0x2d621)[0x557083b6f621]
[taylor-Precision-T1700:31634] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7fd0d5ed8b97]
[taylor-Precision-T1700:31634] [ 7] rhoPimpleFoam(+0x3514a)[0x557083b7714a]
[taylor-Precision-T1700:31634] *** End of error message ***
mpirun noticed that process rank 7 with PID 0 on node taylor-Precision-T1700 exited on signal 8 (Floating point exception).
tenichols19 is offline   Reply With Quote
Old   October 17, 2019, 02:17
Ruiyan Chen
cryabroad is on a distinguished road
In the very first PIMPLE iteration you have 1000 iterations running to try to get the e field to converge, that normally signals ill-posed boundary conditions somewhere. What are you simulating? What are the boundary conditions?
cryabroad is offline   Reply With Quote
Old   October 17, 2019, 05:11
Carlo_P
Carlo_P is on a distinguished road
Yu have also only 1 iteration in the velocity.
Reduce the value in the FvSolution of relTol and tolerance in the solver/U command.
This can help, but as suggested, seems that you have a bigger errors somewhere.
Is the mesh ok? Did you run checkMesh?
Carlo_P is offline   Reply With Quote
compressible flow, openfoam, ras, turbulence
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
