boundary conditions for compressible problem..
Old   October 10, 2019, 14:27
Default boundary conditions for compressible problem..
anonymous
tenichols19 is on a distinguished road
I'm doing a compressible flow problem where my goal is to find the pressure drop across the flow system at a particular flow rate.
Things I know: The flow rate. I will either set the inlet and outlet to either a fixed velocity or mean velocity condition. But since it's a compressible flow problem I should probably implement a mass flow rate condition..
Things I don't know: The pressure drop across the system. I will be setting the the outlet to a fixed pressure 0 or atm, but I am unsure about the inlet.. I've heard the zeroGradient condition should work but I'm unclear about how it works.. If it has a zero gradient from the inlet patch to the internal patch, as the definition says in the documentation, how would a gradient be developed? I think I'm just reading this condition wrong.
Any help or advice would be appreciated.
tenichols19 is offline   Reply With Quote
boundary condition, compressible flow, openfoam, pressure conditions
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Out File does not show Imbalance in % Mmaragann CFX 5 January 20, 2017 11:20
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
