October 8, 2019, 05:32 |
Limiting volume fraction in interFoam
Sita Drost
Rep Power: 18 |
Hi all,
Does anyone have some tips on how to limit the volume fraction in a free surface simulation using interFoam + LTS + semi-implicit MULES? I'm simulating a ship hull at constant (final) velocity, on flat water (OpenFOAM-7, Scientific Linux 7). What I've already tried is:
I'd greatly appreciate any help with this! Many thanks, Sita Code:
Starting time loop forces forces: Not including porosity effects Flow time scale min/max = 1, 1 Smoothed flow time scale min/max = 1, 1 Time = 1 PIMPLE: Iteration 1 smoothSolver: Solving for alpha.water, Initial residual = 0, Final residual = 0, No Iterations 1 Phase-1 volume fraction = 0.800151 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.800151 Min(alpha.water) = 0 Max(alpha.water) = 1 GAMG: Solving for p_rgh, Initial residual = 1, Final residual = 0.00265042, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.00738649, Final residual = 6.70127e-05, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.00164859, Final residual = 1.27058e-05, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 0.000374371, Final residual = 3.73205e-06, No Iterations 7 time step continuity errors : sum local = 4.17722e-06, global = 1.11554e-07, cumulative = 1.11554e-07 GAMG: Solving for p_rgh, Initial residual = 0.00181009, Final residual = 1.05501e-05, No Iterations 6 GAMG: Solving for p_rgh, Initial residual = 0.000606215, Final residual = 4.91912e-06, No Iterations 4 GAMG: Solving for p_rgh, Initial residual = 0.000128742, Final residual = 1.28266e-06, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 4.12132e-05, Final residual = 4.67321e-08, No Iterations 34 time step continuity errors : sum local = 5.256e-08, global = 4.63798e-10, cumulative = 1.12018e-07 PIMPLE: Iteration 2 smoothSolver: Solving for alpha.water, Initial residual = 0.00373314, Final residual = 9.88023e-09, No Iterations 194 Phase-1 volume fraction = 0.80014 Min(alpha.water) = 0 Max(alpha.water) = 1 MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.80014 Min(alpha.water) = -0.994681 Max(alpha.water) = 1.26243 GAMG: Solving for p_rgh, Initial residual = 0.643277, Final residual = 0.0025636, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.000239485, Final residual = 2.04436e-06, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 8.292e-05, Final residual = 6.51857e-07, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 2.60221e-05, Final residual = 2.48377e-07, No Iterations 7 time step continuity errors : sum local = 2.63399e-05, global = -2.08929e-06, cumulative = -1.97727e-06 GAMG: Solving for p_rgh, Initial residual = 0.000181122, Final residual = 1.76238e-06, No Iterations 6 GAMG: Solving for p_rgh, Initial residual = 3.24913e-05, Final residual = 3.01908e-07, No Iterations 6 GAMG: Solving for p_rgh, Initial residual = 8.87704e-06, Final residual = 8.24178e-08, No Iterations 9 GAMG: Solving for p_rgh, Initial residual = 4.60003e-06, Final residual = 4.48455e-08, No Iterations 7 time step continuity errors : sum local = 9.93412e-06, global = 7.66582e-07, cumulative = -1.21069e-06 PIMPLE: Iteration 3 smoothSolver: Solving for alpha.water, Initial residual = 0.0051518, Final residual = 9.5141e-09, No Iterations 193 Phase-1 volume fraction = 0.800275 Min(alpha.water) = 0 Max(alpha.water) = 8.08354 MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water MULES: Correcting alpha.water Phase-1 volume fraction = 0.800276 Min(alpha.water) = -40.6607 Max(alpha.water) = 36.5421 GAMG: Solving for p_rgh, Initial residual = 0.0259583, Final residual = 0.000113245, No Iterations 2 GAMG: Solving for p_rgh, Initial residual = 0.000229723, Final residual = 2.13199e-06, No Iterations 6 GAMG: Solving for p_rgh, Initial residual = 3.9345e-05, Final residual = 3.29743e-07, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 6.93932e-06, Final residual = 6.35426e-08, No Iterations 7 time step continuity errors : sum local = 3.15815e-05, global = 3.83816e-08, cumulative = -1.17231e-06 GAMG: Solving for p_rgh, Initial residual = 9.03879e-05, Final residual = 6.14209e-07, No Iterations 5 GAMG: Solving for p_rgh, Initial residual = 6.38855e-05, Final residual = 5.87189e-07, No Iterations 6 GAMG: Solving for p_rgh, Initial residual = 4.8023e-06, Final residual = 4.93757e-08, No Iterations 9 GAMG: Solving for p_rgh, Initial residual = 1.0839e-06, Final residual = 4.14584e-08, No Iterations 2 time step continuity errors : sum local = 7.41179e-06, global = -1.83339e-07, cumulative = -1.35565e-06 smoothSolver: Solving for omega, Initial residual = 6.41347e-05, Final residual = 6.31364e-06, No Iterations 27 smoothSolver: Solving for k, Initial residual = 1, Final residual = 0.0949203, No Iterations 5 ExecutionTime = 11.67 s ClockTime = 17 s forces forces write: sum of forces: pressure : (307.111 -1016.58 1924.9) viscous : (0.437865 1.16819 6.12748) porous : (0 0 0) sum of moments: pressure : (-224.651 35978.2 23389.1) viscous : (1.46676 96.1615 -17.0622) porous : (0 0 0) Flow time scale min/max = 6.73609e-08, 1 Smoothed flow time scale min/max = 6.73609e-08, 0.00624496 |
October 16, 2019, 05:02 |
Sita Drost
Rep Power: 18 |
Great, I think I found the solution myself: it looks like my initial conditions were off. I've changed some values, and up to now my simulations are running fine.
January 11, 2023, 03:44 |
followup
Shai Aser
Rep Power: 11 |
Hi Sita,
what were the changes that you applied to the initial conditions ? Cheers, |
January 11, 2023, 09:04 |
Sita Drost
Rep Power: 18 |
Hi Shai,
I'm really-really sorry, but I've changed jobs in the meantime; I'm in bio-fluid dynamics now, so I'm no longer using interFoam, and I can't remember what settings I used back then. Reading back my post, I'm pretty annoyed with myself for not writing exactly which initial conditions I changed! As far as I can remember, I gave up using LTS altogether in the end, because it turned out that practically all my simulations would run fine without it. Sorry I couldn't be of more help! Sita |
January 11, 2023, 09:10 |
Hi again
Shai Aser
Rep Power: 11 |
So you went with regular Euler without compromising the time-step errors ?
January 11, 2023, 10:56 |
Sita Drost
Rep Power: 18 |
I did indeed, worked for me most of the time (we used a commercial mesher, Hexpress, by Numeca). I never got to fully testing everything in all sorts of cases, though.
January 11, 2023, 11:06 |
Thank you
Shai Aser
Rep Power: 11 |
Ok thank you very much!, Also for the tip on numeca. I'll check them out
June 5, 2024, 12:58 |
Giles Richardson
Rep Power: 14 |
thanks - some great suggestions there
for reference its: rDeltaTSmoothingCoeff 0.05; // up to 0.5 rDeltaTDampingCoeff 0.5; Last edited by ufocfd; June 5, 2024 at 14:23. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 04:41 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 10:56 |
the Eulerian model and the lower volume fraction | hx li | FLUENT | 2 | October 27, 2005 07:17 |
